48 bit support in CyberGraphX/Datatypes/...
  • akl
    akl
    Posts: 10 from 2004/7/31
    On the AROS-Dev mailing list I've made a proposal to extend the AmigaOS (Clone) API with support - i.e. a corresponding PIX/PBAFMT - for 48/64 bit bitmaps.
    I'd appreciate everyone interested to participate in the discussion thread there - it would be important to sync this API extension among AOS4/MOS and AROS anyway.
    As a short summary - the idea is to add the following:
    16:16:16 RGB (48 bit)
    16:16:16: RGBA (64 bit)
    in addition to the conventional:
    8:8:8 RGB (24 bit)
    8:8:8:8 RGBA (32 bit)
    This is supported already today by PNG and TIFF and required for professional image processing / video editing systems - even though you won't find any conventional framebuffers which directly support it.
    Still it would be helpful, if not the application but the OS would take care how to render/convert this "high data range" bitmap data.
  • »13.04.07 - 10:43
    CISC
    Posts: 619 from 2005/8/27
    But exactly because of this what would be the point? There would be no benefit, and only extra overhead involved in conversion back and forth...
    Besides, there's far more interesting floating-point formats which atleast are displayable with most recentish gfxcards .. either way, all these HDR formats are mainly suitable for editing, and as such I can't say I see the big use in OS handling of them, most of the time you are doing highly specialized tasks with them anyway...
    - CISC
  • »13.04.07 - 11:19
    Krashan
    Posts: 1107 from 2003/6/11
    From the CyberGraphX documentation: Many of this pixel formats are device specific and should not be used, recommended formats are PIXFMT_LUT8, PIXFMT_RGB16, PIXFMT_RGB24 and PIXFMT_ARGB32.
    Then you are wrong supporting RGBA, ARGB is recommended as device independent intermediate format. As Reggae will be an integral part of forthcoming MorphOS 1.5/2.0, it will incrementally replace datatypes, as it gets more decoders. Reggae uses ARGB32 as processing format (so called "common" format), and is prepared to support ARGB64 as well. ARGB64 will appear in Reggae when the first image format supporting 16 bits per component will be added, it is expected to be PNG.
  • »13.04.07 - 11:22
    jcmarcos
    Posts: 1178 from 2003/3/13
    Mmmm...
  • »13.04.07 - 12:46
    Krashan
    BBRV already have announced MorphOS 2.0 here, so why are you surprised? ;-)
  • »13.04.07 - 12:54
    jcmarcos
    The term "mmm" does not mean surprise, it's more like... er...
    GIMME GIMME!
  • »13.04.07 - 13:18
    AmigaMancer
    Posts: 265 from 2005/8/25
    48bit??! Does it really makes a difference to the eye from a 32bit picture?
    Amiga 1200 user.
  • »13.04.07 - 14:20
    Krashan
    There is no such thing like 32-bit picture. It is 24-bit one with 8 bits just ignored or used for transparency, but still you have 8 bits per RGB component. And what is the difference between 24 and 48? You can probably see it only on intentionally prepared images (like some slow changing gradients). The difference is in processing, if you do a lot of operations on 24-bit data, rounding errors (and other errors caused by integer arithmetic) accumulate, and the quality degrades. So possibility to process image in 48 bit (+ optional 16-bit transparency) is an advantage, you get better quality, of course at a price of processing speed. For the same reason recording studios process sound in 24 bits (in spite you can't "hear" the difference between 16 and 24 anyway).
  • »13.04.07 - 16:01
    magnetic
    Posts: 2129 from 2003/3/1
    Krashan + CISC
    Just wanted to say glad you guys are in the community! Very interesting thread.
    magnetic
    BTW you can call is "1.5" "2.0" "OS5" or "XrayAlphaOmega8" if you want but when the hell is it going to come out?
  • »13.04.07 - 16:20
  • DDJ
    DDJ
    Posts: 99 from 2003/2/23
    Let me try...  :-D , when its done?  :-) .
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »13.04.07 - 18:12
    srbin
    Posts: 44 from 2006/11/23
    Wait wait wait, i have another one:
    Both mos 1.5 and OS4 will come on efika
    hmmmm....
    May the force be with you. Don't let the dark side of PC take over you.
  • »13.04.07 - 20:02
    diezi7
    Posts: 167 from 2005/7/25
    (Both mos 1.5 and OS4 will come on efika)
    Well, then I?ll purchase 1.5 Efikas of course !!
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »13.04.07 - 20:16
    Posts: 186 from 2003/10/23
    hmmmm....
    wait .........
    i hope mos 1.5/2.0 will work on x86 machines :P:P
    And now the mantra is completed!
    :-D  :-D  :-D  :-D
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »13.04.07 - 20:16
    Posts: 3297 from 2003/3/5
    If you use 48bit internally for processing then yes, it does make a lot of difference. (that's obviously a HDR made out of 3 24bit raws)
  • »16.04.07 - 07:03
    CLS2086
    Posts: 168 from 2005/8/25
    Actual scanners use 48 bits technology.
    So let see what will happen
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »17.04.07 - 17:15
