important G4 CPU-Card issue
    judas
    Posts: 175 from 2005/1/14
    after closing the CD-Tray, my PEG2 suddenly crashed. After a long investigation, i found the reason:
    Between the G4 and the cooler, there's some copper clued onto the cooler. The clue seems to fail and parts of the copper contact the capacitors of the G4.
    I hat to cut the copper to fit on the G4 ( + 1mm around).
    I hope this will be fixed on future G4's as it is pretty dangerous .... and please use a higher quality fan, too
    bye
  • »25.11.05 - 04:30
