CPU's supported
    Posts: 4 from 2005/9/6
    hi Im prob about to ask the dumbest question but, does the morphOS support x86 CPU Architecture and if not where I can aquired hardware to build a pc that does. Im trying to put morphOS on my old Pentium2 oh btw my vidcard is a pci can't remember the brand though.
  • »06.09.05 - 04:19
    BigGun
    Posts: 150 from 2004/6/18
    MorpOS is a real operating system and only runs on real CPUs.
    If you want to run an Amiga OS on x86 CPUs then you should try out AROS http://www.aros.org
    If you want to use MorphOS then get a Pegasos / Open Desktop Workstation
    from Genesi. http://www.genesi.lu
    MorphOS does run great on them.
    [ Edited by BigGun on 2005/9/6 14:39 ]
  • »06.09.05 - 04:35
    thanks for the help I haven't used anything related to the commodore in so long kinda to bad I forgot how to program on the old C64 and C128 sweet machines as far as classic's go to me a good classic never goes out of style and the still beating heart and OS of the amiga is deffinately proof to that....... thanks again though the help is appreciated..
  • »06.09.05 - 04:58
    number-one
    Posts: 17 from 2005/8/25
    It exist a version X86 of MorphOS.
    See http://rc5.morphos-news.de
  • »06.09.05 - 05:00
    Posts: 199 from 2004/2/9
    I believe you did a mistake. Morphos only runs on Pegasos HD and not on X86.
    As Biggun said, get a real and efficient device, PEGASOS ! :)
  • »06.09.05 - 05:07
    Chain-Q
    Posts: 350 from 2003/10/12
    It exist a version x86 of MorphOS.
    Yeah, and RC5 stat page is the proof for everything. MAYBE a kernel was compiled for x86, for a test, but i very much doubt that a fully featured MorphOS will run on x86 hardware, in near future (let's say in the next 10 years) if ever. It was discussed gadzillion times, why. You have to throw away backwards compatibility, because of endianness, and other reasons. So, forget this for once and for all, thank you.
    Anything beyond this point is pure speculation, and only exists because the lack of real technical knowledge of x86, PPC, and MorphOS internals. Doesn't matter what do you think, it will not happen, because of a reason. Just live with this.
    [.Hosting AmigaSpirit.hu.]
  • »06.09.05 - 05:21
    geez I just asked you don't need to go hadcore on me like I said at the start of the topic I haven't used anything past commodore in years as in like 10 years almost. All my knowledge goes towards some areas of Microcrap Windows and Linux other then that I explore other alternatives so that I may broaden my OS horizons and knowledge of.
  • »06.09.05 - 05:30
    DJBase
    Posts: 745 from 2003/4/6
    MorphOS is for PowerPC only and runs on Pegasos as well as PowerUP-Amiga (Classic-Amiga with PowerPC accelerators).
    If you want to try or use AmigaOS on your x86 Box the best way is WinUAE and AmigaSYS as preconfigured AmigaOS environment (needs a valid KickROM and Workbench ADFs).
    [ Edited by DJBase on 2005/9/6 19:23 ]
  • »06.09.05 - 06:21
    jcmarcos
    Posts: 1178 from 2003/3/13
    FoxFire1 wrote:
    geez I just asked you don't need to go hadcore on me...
    Don't worry, FoxFire1, actually, that reply wasn't aimed at you. It's only that MorphOS for Intel (which doesn't exist, really) raised some hot discussions before.
  • »06.09.05 - 06:38
    Chain-Q
    Sorry, if i went a bit further than i should, but this is one of the areas (MOS on x86) which really was discussed a lot of times, still it appears again and again, so it's a bit boring at least. :)
  • »06.09.05 - 07:02
    Posts: 2095 from 2003/6/4
    MorphOS supports PowerPC only. In detail the following proccesors are supported :
    AIM designs (manufacturer: Motorola (now Freescale)) 603e and 604e
    IBM750,
    Freescale 5200, 7400, 7447(A) and 7448
    Not officially confirmed (but should work, too) is AMCC 405 and 440.
    Computerplatforms supporting MorphOS are:
    - Genesi Pegasos 1 and Pegasos II
    - Commodore/Escom Amiga with Phase 5 ppc accelerator board.
    - Freescale mobileGT (not public)
    - Genesi Efika 5k2 (not public)
    - AMCC 405 evaluation boards flashed with smart firmware (not public and not confirmed)
    In short: currently the Pegasos is more or less the only device for MorphOS, you may have alook at ebay, the Pegasos1 is quite cheap but picky on ram (overall performance is a bit less than the PegasosII).
  • »06.09.05 - 07:57
    zephar123
    Posts: 139 from 2004/3/8
    goto genesi website to buy your peg2 =). YOull love the mobo and the os even more =). Peg2 also runs linux which is nice and can run mac underemulation.
    http://genesi.pegasosppc.com/
    look forward to seeing you here asking questions on your new machine =)
  • »06.09.05 - 12:12
    cool i'll deffinately look into getting an amiga pegasos2 kinda sounds like it would make a good server too, which I could really use cause I do alot of server stuff but i'll put that up there on the list with the new AMD system Im building.
    [ Edited by FoxFire1 on 2005/9/7 4:09 ]
  • »06.09.05 - 18:42
