Mos 1.4.5 Problems PLEASE HELP!!
    shedroveme2
    Posts: 26 from 2005/5/9
    Just tried to boot off the 1.4.5 CD, after the Quark/Openfirmware message screen goes blank(NO SPLASH SCREEN), and then my monitor goes into powersave, then nothin happens.
    Was running 1.4.3 OK
    Any help would really be apreciated.
    Thanks
    PegasosII 1GHZ
    Radeon 7000
    512MB DDR
    30GB HDD
    32x Sony CDRW
  • »09.05.05 - 16:49
    Posts: 236 from 2003/7/28
    1) If you have any PCI USB cards in your Pegasos-2 remove them.
    2) Try re-burning the CD - perhaps it's a bad copy.
    3) Try a different monitor. Perhaps your monitor is not able to scan to the boot up frequency.
  • »09.05.05 - 17:24
    shedroveme2
    1) No pci usb cards no usb devices at all
    2) re downloaded and re burned, no change
    3) tried different monitor no change
    tried different memory & cdrom drive, still no change
    out put from debug is as follows
    ABox 1.10 (24.7.2003) © 1999-2003 by Ralph Schmidt, Emmanuel Lesueur, Teemu Suik
    ki, Harry Sintonen
    VIA ATAPI Driver: Unit 2 set PIO Mode 4
    VIA ATAPI Driver: Unit 2 set DMA Mode 2
    VIA ATAPI Driver: Unit 2 set UDMA Mode 5
    VIA ATAPI Driver: Unit 3 set PIO Mode 4
    VIA ATAPI Driver: Unit 3 set DMA Mode 2
    VIA ATAPI Driver: Unit 3 set UDMA Mode 2
    ide.device: Unit 2 ATA-HD IC35L030AVV207-0 <DIRECT_ACCESS>
    ide.device: Part <DH0> DosType 0x444f5301
    ide.device: Part <DH1> DosType 0x53465300 BootPri 0
    ide.device: Unit 3 IDE DVD-ROM 16X <CDROM>
    ide.device: CDRom <CD001>,<MORPHOS > found, bootable
    ide.device: Part <CD0> DosType 0x43444653 BootPri 127
  • »09.05.05 - 17:56
    shedroveme2
    !!!SORT OF FIXED!!!!!
    Done a manual install, booting from my already installed 1.4.3, and it works fine!!!
    Can't understand it my self but happy that it works.
  • »09.05.05 - 18:14
    killlbilll
    Posts: 95 from 2004/5/19
    In 1.4.5, the bootpicture seems to run in a different screenmode than before. My monitor resyncs from openfirmware -> bootpicture and bootpicture -> ambient. If this could have some impact on your system, i dunno.
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »09.05.05 - 18:57
    Posts: 35 from 2003/6/11
    hi
    interestin! i thought i was the only one to have this sort of problem. . .
    i have a peg1 april2, 1 gig ram, radeon 7500 etc.
    i will try a manual upgrade soon. but the boot cd should work for everyone.
    (btw: this definitely is no matter of a wrong screenmode or something. . .)
    kind regards
  • »09.05.05 - 21:50
    shedroveme2
    dunno how could be a matter of wrong scrreenmode i have a elonex 21" monitor and it handles pretty much every resolution you can think of.
    Unfortunatly 1.4.5 does seem to be freezing a bit when trying to set a background picture & a reboot is necssary dunno what that's all about, i think i might just go back to linux.
  • »10.05.05 - 11:10
    SoundSquare
    Posts: 1213 from 2004/12/1
    gosh it may be a stupid question but are you sure u're booting the Pegasos 1 img file ?
    boot the bootpeg1.img and not boot.img
  • »10.05.05 - 13:24
    shedroveme2
    why would i want to use the Peg1 img on a peg 2.........
  • »10.05.05 - 14:27
    The_Killer
    Posts: 3 from 2004/5/17
    The same problems here with MOS 1.4.5 !
    plz. hlp...
    The_Killer
  • »14.05.05 - 17:54
