pegasos 1 with april fix bios update
    klapdeur
    Posts: 132 from 2003/6/28
    Hi guys i hope i can find any help here im still searching for a bios
    update for a peg 1 with april fix
    ive heard that theres a update . i need it because i bought a while
    ago a symbios scsicart and if i put it in to my peg not even the
    firmware is showing up just nothing happends. now ive been told by Ron
    van herk from computer city. that i need a firmware or bios update for
    my peg because this scsicart should be working on a peg 1 its a cart
    with the 810 symbios chip.
    hope you guys can help me out here
  • »14.01.05 - 14:27
    Robin
    Posts: 741 from 2003/2/24
    I'm sure it was on bplans website. But cant find it.
    Just try contact them:
    http://www.bplan-gmbh.de/contact.html
  • »14.01.05 - 15:19
