What happened to the RC5-72 ?
    Posts: 278 from 2003/3/4
    2004-10-05 682,907 5,408
    2004-10-04 677,499 3,521
    5408 blocks in one day :-o
    That's about 2000 blocks above average.
    Did someone worked on these 2000 blocks for a long time and released them yesterday ?
    [edit]
    2004-06-21 352,170 5,173
    Looks like it already happened before.
    It may be 3+ months of work from 1 Peg.
    [/edit]
    [ Edited by cdfr on 2004/10/6 13:26 ]
    [ Edited by cdfr on 2004/10/6 14:52 ]
  • »06.10.04 - 18:16
  • JBB
    Posts: 32 from 2004/5/27
    Hey!
    I've been crunching numbers for months, a few hours a day on my G3 (so, well, not much... but it's better than nothing!)
    I'm just suddenly in doubt:
    How do you "release" the blocks you've been crunching?
    Simply by quiting the app?
    JBB
  • »06.10.04 - 19:24
    Krashan
    Posts: 1107 from 2003/6/11
    If you use MUI GUI just "Update" from menu, it will send crunched blocks and fetch next batch. If you are running dnetc in a shell just use 'dnetc -update'. It should be all automatic however if you are always connected to the net when crunching, manual update is mainly for poor dial-uppers...
  • »06.10.04 - 19:55
    Posts: 1520 from 2003/2/24
    You can write an ARexx script to flush buffer when you go online.
  • »06.10.04 - 21:03
  • HAK
    Posts: 225 from 2003/2/24
    Hi cdfr,
    Well, not necessarely.
    An unused Peg1 can throw out around 40 blocks per day.
    Meaning this would only take 50 days for those 2000 blocks.
    Bye HAK
  • »07.10.04 - 00:19
    Posts: 261 from 2003/3/13
    Anyone noticed AmigaOS/PPC is catching
    up on us ?
    MOS 1.5 Altivec !!! :)
  • »07.10.04 - 09:05
    MarK
    Posts: 641 from 2004/1/25
    That's my 'fault'... I was computing many weeks and I didn't get online very often...
    Here is my history... :-)
    Bye, MarK.
  • »07.10.04 - 14:58
    AyoS
    Posts: 410 from 2003/8/13
    Definitely not Your "Fault" MarK, its just a little moral booster!!!
    Hopefully we can catch dosx86 by november, that will give us a reason
    to crunch...
    ...Yes Altivec and Mos1.5 sooon, Please... :-)
    [ Edited by katos1 on 2004/10/7 23:14 ]
  • »08.10.04 - 04:12
