Welcome new MorphOS Users!
    tokai
    Posts: 1289 from 2003/2/25
    Hi all,
    since the dealers (GSS, Vesalia, ...) obviously have Pegasos2 in stock again, I'm sure we will see a lot 'new faces' here on MorphZone.org in the next days/weeks.
    Besides the saying of "Welcome!" I think it's a good idea to share our experience with the new users.
    Back then in 2003 when I got my Peg1 I also had a lot 'newbie' questions, and a similiar (successful) thread on amiga-news.de (yup, back then i didn't knew about mz.org) helped a lot of us to solve first problems or getting answers. So I hope this very thread will become also succesfull and helpful for the new users w/o the need to search around a lot in old topics.
    So please keep this thread on top the very next days by posting useful information and tips which could help new users. And new users can post questions here, w/o to have fear to ask something again wich was asked already a lot in old topics. :-)
    Information:
    Help on IRC:
    besides morph.zone you also can join an IRC channel for getting quick help (most of the time a lot very helpful ppl are around). You can access the channels with the mz.org webinterface (after you logged in) or by using an IRC client and join ARCNET (de3.arcnet.vapor.com or full serverlist: http://www.arcnet.vapor.com).
    Channels:
    #morphos - general morphos related support, discussion, etc.
    #morphzone - the official mz.org channel
    #morphsdl - sdl developer channel
    #phoenix - channel of the phoenix developer consortium
    #amiganews.de - channel of amiganews.de, but since most of the time only morphos users are around we could call it the 'german morphos channel' ;-)
    FAQ'n'Guides:
    more useful information about certain topics you find here:
    * Install.guide on morphos-news.de (available in different languages)
    * MorphZone.org FAQ
    * Tutorials on morph.zone
    * Miami installation w/o using Installer
    There are a lot more help sites available (also in other languages than english), but i do not know them all, but good help sites are: http://www.amiga-news.de /forum (DE), http://pegasosforum.de (DE), http://pegasos.org, etc., best is to check out the morph.zone link database.
    Software
    Morphos native and supported software you'll find here:
    * morphos-news.de software link database
    * morph.zone downloads
    * aminet
    * MorphOS SDL Support site
    * and on a lot other places.
    TIP: even if you're not a developer (yet) it's very usefull to install a MorphOS Software Development Kit (SDK). It contains a so called 'geeks gadget environment' which contains a lot helpful tools and a proper setup which certain software (e.g. quick unix ports) needs. And you'll also get MorphED. ;) You can download the full SDK after registration on mdc.morphos.net.
    So, now: A Happy welcome all new MorphOS users!! [placeholder for the party smilie] (jeez, now i wanted to add the P-A-R-T-Y smilie, but he's broken atm., Targhan: fix fix! ;-) )
    And you 'old users': fill this thread already with usefull information until the 'newbies' arrive. Or simple: be helpful like in the past! :-D
    Thanks.
    regards,
    tokai
    [ Edited by tokai on 2004/8/3 11:20 ]
  • »03.08.04 - 07:19
    Posts: 2065 from 2003/6/4
    tipps for hardware issues:
    Remember to use only 80-wire ata cables (not only for hd but also for cdrom).
    Best if buying Ram at your Pegasos dealer (he knows the best types)
    Read the specs of the interanl connector carefully. Cabling the internal usb connector:
    At the mobo there are four panels near the memory slots present. Two of
    them (the both neigbouring to th ecpu slot) are for IDE, then there
    are two more left one for the floppy (well noone needs this..) and one
    26 pin connector (just neighbouring the memory slot) for multiple
    purpose. If you look at that connector there are two rows of pins. If
    you look to the mobo that the front panel of the Peg (i.e. the
    external ports like parallel, usb, ps/2) are on your left hand you
    have to count the pins of that connector from the top on. The
    right pin row starts from the top with one not used pin and then
    4 pins for usb connectivity starting with (counting from top
    downwards!!)
    - gnd
    - usb signal D+
    - usb signal D-
    - usb 5 volts
    your case should offer four cables per usb connector on the front.
    These cables should be taged somehow like usb1 gnd, usb1 D+, usb1 D-,
    usb1 5V and the same set with usb2 gnd, usb2 D-, ... Choose the 4
    cables according to one connector and plug them into the connector.
    Take care that you dont mess up one of the cables, your Peg would not
    thank you that!
    Again all pins on the right row of the connector
    1 - not used
    2 - usb gnd
    3 - usb D+
    4 - usb D-
    5 - usb 5V
    6 - KCLK
    7 - KDATA
    8 - -SCLK
    9 - SDATA
    10 - HDD LED +
    11 - Power LED +
    12 - Reset (pin A)
    13 - Power on (pin A)
    The left row is
    1 - PC speaker Pin A
    2 - not used
    3 - not used
    4 - PC speaker Pin B
    5 - IRDA power supply
    6 - IRDa RX2
    7 - IRDA RX
    8 - IRDA GND
    9 - IRDA TX
    10 - HDD LED -
    11 - Power LED -
    12 - Reset pin B
    13 - power on pin B
    Do not hesitate to ask for further details...
  • »03.08.04 - 08:12
    bbrv
    Posts: 751 from 2003/2/14
    That is very nice of you two!
    MorphOS Medal to Zylesea and a gold star to tokai for the MOS Medal he already has...;-)
    R&B :-)
  • »03.08.04 - 09:57
    Posts: 26 from 2003/9/9
    Thanks, nice overview of some useful links!
    One question, does the Peg need a powersupply with one of these 12V square 4 pin connectors? It is not included on many older ATX powersupplies (but I found out it was required by newer motherboards, so apparrently the ATX PSU specification has changed).
  • »03.08.04 - 10:34
    breed
    Posts: 33 from 2004/7/6
    @Tokai: Thanks for all your work!
     :-D
    Download FroGGui and my tracks here
  • »03.08.04 - 12:39
    There is 12 V on Pin 10 of the 20 pin standard connector of ATX PSUs. No extra connectors needed.
    IIRC new SATA devices need new power connectors but since SATA is not present on the Peg (well, UDMA 100 is quite speedy, only advantage I see for SATA currently would be that the cabling becomes a bit nicer) there is no need for SATA power connectors.
    You can happily use every ATX PSU out there (given the fact that it is not out of order ;-)).
  • »03.08.04 - 13:11
    GMKai
    Posts: 257 from 2003/4/7
    to all the new guys out there:
    be prepared for MVP, an share- and freeware package soon to be finished.
  • »03.08.04 - 14:13
    Posts: 1077 from 2003/3/24
    @ GMKai: What is that MVP? Please tell me more. :-?
  • »03.08.04 - 14:34
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    I believe you are speaking of the Pentium 4 'extra juice' connector....no, the Pegasos (neither 1 nor 2) requires this connection....just the regular ATX (20 pin?) power connector
    Steve
  • »03.08.04 - 14:41
  • DDJ
    DDJ
    Posts: 99 from 2003/2/23
    Software tips:
    morphOS 1.4.2 don´t have a lot of needed files "libs, etc..." for your old apps and games, so be carefull and use a monitor system like SnoopDOS to see wath is missing, copy only the needed files for your old apps, and try to avoid mix the 68k files with the .elf ones, i mean don´t replace the files inside YOUR-MORPHOS-SYSTEM-HD:Morphos/, they are all MOS PPC Native and need to be replaced ONLY when you really know wath are you doing, the old files (68k) must go to the folders outside this location, following this "rules" i guess your setup will probably be out of troubles and MOS will be healt allways .  :-D
    [ Edited by DDJ on 2004/8/4 16:31 ]
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »03.08.04 - 15:25
    GMKai
    about MVP ( not MCP):
    it is a collection of share- and freeware that is installed via a Hollywood-Exe.
    For now it includes about 70MB Software.
    The package is going into Betatest right now.
    It includes MUI-Classes, Internetsoftware, tools and games.
    For advanced users its not that neccesary to download it, but maybe you can have a look later.
    cu
  • »04.08.04 - 04:18
  • Targhan
    Posts: 2833 from 2003/2/7
    For the users who're old school amigans, the best advice I can give is to simply make your old Workbench: partition available for file copies. It's quite amazing how quickly a new MorphOS install can feel like home if you can use Opus or Filer to snatch up missing libs for your favorite applications.
    Everyone should be wary of installers, and should always select "create a logfile" when using installer. I cannot count the times over the years that an installer's logfile has saved my data.
    Those completely new to MorphOS should learn a few real basics:
    Right "Command" + E, brings up the "execute command" box, very useful for quick commands such as "Assign TempName: RAM:"
    Instead of "tabbing the icons," if the batteries in your cordless mouse goes out--hold the Left Command key down, and use the arrows to move the mouse. To left and right click, use LCommand+ALT and RCommand+Alt respectively.
    I probably reiterated someone else's advice n' such, but some of the basics are always the same. ;-)
    :idea:Targhan
  • »04.08.04 - 06:11
    Posts: 911 from 2004/1/24
    Here's a really practical advice ;-) :
    When you encounter a problem (if it be hardware or software related) feel free to start a thread or ask the helpfull and wise people on the morphos #irc channels, but....always search in the forums of MorphZone first! In the time that MorphZone has gone online, it has gathered an incredible ammount of information within it's thread/forum archive.
    A quick how-to:
    1. Use the "Search" box on the front page and enter keywords of your problem; tadaa :-)
    You can almost everytime find an old thread about a similiar problem you're dealing with, and if it doens't answer your question, just resurrect it. And if you cannot find any thread related to your problem, than a new thread would most definitly be in place :-)
  • »04.08.04 - 09:05
    Posts: 4 from 2004/8/4
    I'm (not yet?) a new PEGASOS user. My Amiga ist still
    standing in the corner but I have not really worked with
    if for years. Some time ago I saw a PEGASOSII demonstration
    and I was impressed and now I saw a nice offer for a complete
    system (without case, mouse and keyboard) for 760 Euro.
    Once I heard that there is this new G4 with less power consumption
    so that you do not need a fan for the 1 GHz version, but I do not think,
    that it is the one used in the current PEGASOS offers. I also heard about
    the G4 with higher clock rates (back then they wrote that PEGASOS
    might support those CPUs when they are available).
    Can anybody tell me, if there will be a PEGASOS with these CPUs in the
    near future or if it is better to just buy the beginners package from Vesalia
    (that I mentioned above) because there will not be a PEGASOS with the
    new CPUs in the near future?
    Is the standard processor fan in the G4 PEGASOS very loud?
    Sorry if someone else already asked the same questions or if this
    is the wrong place for this posting.
    Best regards
    (Dent)
  • »04.08.04 - 15:24
    golantrevize
    Posts: 13 from 2003/8/3
    I'm a new peg user!!!!! probably tomorrow when I'll get my peg1 from another pegasos user who did the upgrade.
    I have here my radeon 9100 and the 80 pin eide cable waiting (beside the case of my dead pc and other pieces of hw) for the peg.
    I have one question, as customer can I download the superbundle from somewhere? I registered to the site but it says that new accounts are suspended. Is there any chance to get it anymore?
    When I'll install mos I'll surely have more questions...
    Bye,
  • »04.08.04 - 16:50
    Black_Eagle
    Posts: 70 from 2003/6/5
    First of all, this is how excited you'll be when you have installed MorphOS on your new Pegasos ;-)
    Happy user
    Ok, I know this is in the manual, but I took pictures of my Pegasos 2 a long time ago and put the names of connectors on them to make it easier too se where stuff goes. And made a small drawing of the misc connector while I was at it.
    External connectors
    Internal connectors
    The misc. connector
    [ Edited by Black_Eagle on 2004/8/5 8:39 ]
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »05.08.04 - 04:38
