Questions about MorphOS
    lerche
    Posts: 14 from 2004/7/25
    Hi there!
    Im very new at MorphOS, so new that i haven't try it out yet. And therefore i have some Questions.
    1. What hardware does fit whit MorphOS, what machines/processor can run it ???
    2. Where do u get MorphOS, can i download it, or do i have to bye it ???
    3. What other kind of software can i get for MorphOS ??
    Best regard's
    Henry Lerche Madsen
    Denmark
    Best regards
    Henry Lerche Rasmussen
    Denmark
  • »25.07.04 - 11:40
    dholm
    Posts: 296 from 2003/9/1
    1. The Pegasos, which runs on either a G3 or G4 CPU. Check out www.pegasosppc.com to find the vendor closest to you.
    2. MorphOS comes with the Pegasos.
    3. Most AmigaOS (up to 3.9) applications run on it. There are also several projects working on MorphOS-native applications.
  • »25.07.04 - 11:57
    tarbos
    Posts: 221 from 2003/4/20
    3. There is the Superbundle and a number of MOS native programs are listed here.
  • »25.07.04 - 18:37
    DoctorMorbius_FP
    Posts: 315 from 2004/2/14
    I will be accused of narcisism, self-advertising, megalomania, etc.. However it seems that, up to now, the ultimate truth about MorphOS and its compatibility with Amiga software can be found in my review, here:
    https://morph.zone/extra/PegasosReview/01_Introduction.html
    Good reading!
  • »25.07.04 - 22:16
    Spidey
    Posts: 568 from 2003/2/24
    Hi DoctorMorbius_FP,
    Nice read. I'll read it thoroughly when I'm home :-)
    @lerche
    Welcome to MorphZone :-)
    1. All kinds of peripherals can be used with the Pegasos. Although I have to say that even then you have to watch out. Not every brand works! As example: my 40GB IBM Realstar harddrive did work with my previous Peg 1, but not with my current Peg 2. But, look on this site and you'll see what works and not :-). The proceesor part is already answered.
    2. If you buy a Pegasos you'll get MorphOS for free. Also you'll get access to the superbundle site and so on. There you can download updates. At the moment we are discussing here whether to pay for future updates or what else.
    3. There are already games specifically made for MorphOS, Knights and Merchants per example. More software are already being made.
    Bye,
    Spidey
  • »26.07.04 - 07:45
