Simple Mail "ToolTypes"
    freepointer
    Posts: 74 from 2015/12/16
    Wer weiss was ???
    Ich möchte gerne SimpleMail über Projekt Icon "ICONIFIZIERT" /wBstartup starten, hat jemand Erfahrungen über diverse Tooltypes steuerung ???
    ICON "X Y " position (beide Icons 1.Postfach 2. Program) zzgl. wäre auch noch schön :)
    CX_POPUP=NO
    ... oder ähnliches ?
    [ Editiert durch m7g5wt 25.08.2015 - 15:08 ]
  • »25.08.15 - 13:06
    Posts: 841 from 2007/10/23
    Read the fine manual:
    AppIcon Show
    You can select the appearance from the AppIcon.
    Always -> Always show the AppIcon.
    Iconified -> Only show the AppIcon when SimpleMail is iconified.
    Never -> Never show the AppIcon
    The normal iconified Icon of SimpleMail can be turned on/off in the MUI-Prefs
    of Simplemail in the "System" group.
    AppIcon Position
    workbench.library < V44 (< OS3.5):
    The position of the AppIcon can be set with the ToolTypes APPICON_POSX
    and APPICON_POSY.
    workbench.library >= V44 (>= OS3.5):
    Use the (Un)Snapshot menuitems from the Workbench->Icon menu. Of course
    you can also use the ToolTypes if you want but the Snapshot function of
    the workbench does have the higher priority if you have used both.
    It's also possible to exit Simplemail by invoke the "Delete" item of
    the Icons menu.
    [ Editiert durch polluks 26.08.2015 - 13:29 ]
  • »26.08.15 - 10:05
    freepointer
    tx...
    i go to Do it your self
    i am look an bring the feedback :) :) :)
  • »26.08.15 - 10:53
    freepointer
    I am look from Mui - not found the Simple Mail ???
    Simple Mail launches, but not iconifiziert
    can be derived from the setting out "only Appicon" or "both APPicons"
    but it would be nice if the Simple Mail Direct Iconifiziert starts
    [ Editiert durch m7g5wt 31.08.2015 - 09:22 ]
  • »31.08.15 - 07:19
