What chance of getting MorphOS2.x for Classic + PPC
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    So as it was by default in MorphOS 0.x on AGA without CGX.
    _
  • »22.08.14 - 23:48
    sabbate
    Posts: 110 from 2013/7/7
    I honestly do not understand why we should emulate morph with few euro when you buy a powermac that is much more powerful emulator
  • »23.08.14 - 10:34
    Um, very true.
    My last purchase of a 2.7 GHz G5 cost about $20.
    The Apple Radeon 9800XT set me back a little more.
    And I had the memory and hard drives on hand.
  • »23.08.14 - 16:05
    redrumloa
    Posts: 1424 from 2003/4/13
    Jim wrote:
    Um, very true.
    $20 for a working 2.7Ghz? Now that is a steal!
  • »23.08.14 - 19:45
    I thought it was a silly good price.
    The hard drive was flaking out and the unit would only produce a blank white screen.
    I swapped out the hard drive and it worked fine.
    Of course nothing is perfect.
    UPS must have dropped the box as the bottom handles are bent.
    But it works fine.
    And since I bought a 9800XT, I have a spare 9600Pro video card.
    I'd like to test that in a G4.
    Some 9600's will work in a G4.
  • »23.08.14 - 20:09
    CountRaven
    Posts: 566 from 2007/12/10
    I wonder if the last PowerUp version would boot under WinUAE.
    Should give it a try.
  • »24.08.14 - 01:52
  • esc
    esc
    Posts: 160 from 2013/5/27
    It doesn't. :)
  • »24.08.14 - 02:39
    Posts: 3210 from 2003/3/5
    Please, forget about AGA.
  • »24.08.14 - 06:52
    diezi7
    Posts: 167 from 2005/7/25
    esc wrote:
    It doesn't. :)
    Bad Bad, I was willing to get that spare card !
    Does PMac G4 support some card model with more than 64MB?
    Regards
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »24.08.14 - 06:56
    Posts: 2451 from 2003/2/24
    There are some genuine Apple 9000(Pro)s with 128MB (got a non-Pro in mine) and flashed&modded 9xxx cards should work as well.
    Now if anybody had a DVI-D able card (256MB would be niece) fit for my QuickSilver, I'd probraly retire the G5 :o)
  • »24.08.14 - 09:18
    I have never seen an Apple 9000 card with more than 64MB of vram.
    Are you sure there are 128MB Apple cards?
    Also, what is the problem with digital output?
    I was not aware of any issue.
    Then again, I have been using R300 cards for awhile.
    [ Edited by Jim 24.08.2014 - 06:17 ]
  • »24.08.14 - 11:03
    a) ibäh
    b) mine has 128MB and an ADC connector (but is only a non-Pro 9000)
  • »24.08.14 - 11:11
    They DO exist!
    Interesting.
    BTW - I have two or three 64MB cards if anyone wants one (free, of course).
    And by DVI-D, I guess you mean dual DVI-D?
  • »24.08.14 - 11:20
    Dual-DVI-D would mean 2 DVI connectors both capable of DVI-D (2560x1600), such cards start to appear somewhere at the 9800s.
    9600s with 256MB normally have 1xDVI-D and 1x(single link)DVI.
    I would need 1 DVI-D, don't care wether the 2nd port is DVI,DVI-D or even VGA.
  • »24.08.14 - 11:37
    So 9000 cards don't support DVI-D.
    Again, I did not know that.
    Do MorphOS drivers support such high resolution connections?
  • »24.08.14 - 12:19
    Since 3.5 (AFAIR).
    Got a 27" Dell (2560x1440) on my G5 (9600/256 from a 2.7GHz model).
    HAK has the 30" (2560x1600) and Frank himself has the 21:9 29" (2560x1080).
    Edit:
    The issue is that all guides I've seen on flashing 9600s or better suggest that the DVI isn't fully functional afterwards.
    [ Edited by Kronos 24.08.2014 - 13:33 ]
  • »24.08.14 - 12:32
    Kronos wrote:
    Since 3.5 (AFAIR).
    Edit:
    Yep, flashed 9600s have issues.
    There are a few Apple 9600s with dual DVI output that will work in a G4.
    I sent one to CountRaven a few months ago.
    Generally they are the earlier cards.
    I have another 256mb 9600Pro if you'd like to try it, but it may only work in a G5.
    I don't currently have a working G4 to test it.
    One advantage, most Apple 9600s do not have ADC connectors.
  • »24.08.14 - 13:20
    Simon
    Posts: 809 from 2008/7/6
    jacadcaps wrote:
    Guess I'll dump some random links for those who missed them:
    http://dreamolers.binaryriot.org/priv/powerup_tease.png
    http://dreamolers.binaryriot.org/priv/powerup_tease2.png
    http://dreamolers.binaryriot.org/priv/powerup_tease3.png
    Need more teasers ... My blizzard with grex wants it.
  • »15.01.15 - 18:13
    CountRaven
    More teasers and a new version for classic ppc :)
  • »15.01.15 - 20:32
    No more teasers by me, sorry. Sold the PowerUP long ago...
  • »16.01.15 - 05:18
    pampers
    Posts: 1061 from 2009/2/26
    Apply few fixes and use WinUAE ;P
    MorphOS 3.x
  • »16.01.15 - 17:28
    MorphDelf
    Posts: 274 from 2004/2/20
    How about porting MorphOS to 68k :) replacing AmigaOS 3.x hehe... I wonder how the speed would be.
  • »19.01.15 - 10:43
    Simon
    Yup, do it in winuae. No more excuses 😃😭
  • »19.01.15 - 18:25
    Posts: 1932 from 2003/10/19
    It would be very interesting to see it run in WinUAE. I have OS4 running and its quite stable and usable.
  • »20.01.15 - 17:36
    WB_Coder
    Posts: 66 from 2014/5/1
    Really? I thought it was more of just a proof of concept, rather than anything that was usable. How fast does the Windows PC have to be to get decent performance running AmigaOS4.x through emulation?
    WB_Coder = Wanna Be Coder
  • »23.01.15 - 01:01
