compatibility list for 68k programs in MorphZone library
    magnetic
    Posts: 2129 from 2003/3/1
    Wei
    Instructions are in the archive. Morphos has support built in once you install it. Very easy peasy
  • »08.07.12 - 09:34
    Posts: 2794 from 2006/3/21
    @Andreas_Wolf,
    > Visionary
    I'd recommend running the MorphOS-native version of that one, unless you refer to a different software product that coincidentally goes by the same name.
    Maybe he was referring to the Amiga 68k Text Adventure authoring language by Aegis? I have it, plus an extra third party book about it in my collection.
  • »09.07.12 - 05:51
    Posts: 1246 from 2004/2/8
    @WeiXing3D
    Now either:
    1. You locate the Pagestream installer script, right-click on it and choose "Open with" providing a path to the 68k installer
    or
    2. Right-click on installation icon choose "Information" and change "Default tool" to the 68k installer path.
    The latter won't work if your adf image is "write protected" (You won't be able to change "Default tool")
    [ Edited by koszer 09.07.2012 - 06:54 ]
  • »09.07.12 - 06:53
    Posts: 12079 from 2003/5/22
    > language by Aegis?
    That may very well be. I wasn't aware of this software existing, thanks. And let's see if he will give a clarification.
    > I have it
    Have you tried running it on MorphOS?
  • »09.07.12 - 09:59
    magnetic
    Yeah I was talking about Visionary by Pega1 the morphos tv card program.
  • »09.07.12 - 10:06
    DrZarkov
    Posts: 142 from 2004/3/21
    Games: I was pretty amazed when I found out by chance that Megaball AGA runs on Morphos! Sound and graphics are perfect, of course the picture is a little bit small, depending to your monitor and resolution. Nothing special installed, just Morphos out of the box.
  • »09.07.12 - 10:55
    boot_wb
    Posts: 874 from 2007/4/9
    Turbocalc 5 - seems to work perfectly (so far), however:
    1) Drop-down menus don't seem to work with a RMB click (or hold).
    The 'launch menus' keyboard shortcut does, however, activate the menus.
    By default this is RAmiga+Space. To reconfigure, go to Settings>System>iControl>Hotkeys>Menu: Launch menus.
    2) Importing Excel files (.xls) does work, however import appears to be limited to Excel 95 versions of files. To import a file into turbocalc saved in Excel 97-2003 (.xls) or Excel 2007+ (.xlsx), it must be saved (using MS Excel) selecting .xls (Excel 95) compatibility from the filetype options.
    I'm pretty damn happy to finally get Turbocalc working properly - both of the above issues have taken a while to figure out.
    An intuitive (familiar formulas, operators, macros) spreadsheet is a vital tool for me - more so than a .doc comaptible word processor. Also, xls import is a major bonus.
    Whimsical aside: Sigh.. I do wish someone with deep pockets would buy out the rights to Digita's Amiga Office software (Wordworth, Turbocalc) - just add .doc/x, .xls/x, (and open equivalents) import/export, and most of the work is done in creating a fantastic office package compatible with all Amiga flavours.
    EDIT: Minor details.
    [ Edited by boot_wb 25.08.2012 - 19:38 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »25.08.12 - 20:28
    I don't think TurboCalc is or was a Digita product.
    "Written by Michael Friedrich - Creative Developments
    Distribuited by Stefan Ossowskis Schatztruhe
    Distributed in italy by NonSoloSoft
    http://www.amiworld.it/programmi/turbocalc/turbocalc_eng.html
  • »25.08.12 - 21:59
    boot_wb
    From the Turbocalc 5 About tab:
    "Digita International is the exclusive world-wide publisher of TurboCalc in English."
    Publisher vs Distributor?
    EDIT: Less certain of Andreas_Wolf's correctness ;-)
    [ Edited by boot_wb 25.08.2012 - 21:16 ]
  • »25.08.12 - 22:13
    boot_wb
    Either way, Michael Friedrich would probably be the one to contact for Turbocalc I suppose.
  • »25.08.12 - 22:18
    Thanks. I wasn't aware of that.
    Whatever these roles imply in this particular case, it may seem that Digita was the sole publisher while there were various national distributors. But taking "in English" into account, it may as well be that regarding TurboCalc, Digita was for the English speaking countries what Schatztruhe was for Germany and NonSoloSoft for Italy, meaning that the terms "publisher" and "distributor" would be interchangeable here.
  • »25.08.12 - 22:29
    Fully agreed, as he would have the source code (and the rights to it).
  • »25.08.12 - 22:32
    Posts: 2053 from 2003/6/4
    Turbocalc is written in Assembler and hence probably rather difficult to develelop further. It's 300.000 lines of code with sparse comments.
    http://www.amiga-news.de/de/news/AN-2002-10-00268-DE.html
    But at least a free version would be nice. I use a rather old version (3.5) because that's the most recent legal version i am in possession of.
  • »25.08.12 - 22:46
    Mequa
    Posts: 51 from 2012/3/30
    Andreas_Wolf,
    No Kickstart ROM version is freeware.
    AROS/68k ROM is. It runs on MorphOS's port of E-UAE too (and ironically on OS4 as well, considering the politicking between OS4 and AROS).
    However, it's a bit slow without JIT-compilation (something the PPC JIT bounty should help). Compatibility with classic AmigaOS software is improving, however - and it'll run hardware banging stuff too.
    [ Edited by Mequa 26.08.2012 - 06:48 ]
  • »26.08.12 - 07:46
    > AROS/68k ROM is.
    True. But if you have a look you'll see that I wrote that back in April 2011 when the AROS Kickstart reimplementation wasn't really usable yet.
    I don't see much of that. There was a remarkable incident in 2007 when Hyperion's managing partner Evert Carton "continued to generate controversy by stating under oath that the open-source AmigaOS reimplementation AROS was "probably illegal"" but according to some AROS developer this isn't anything to worry about:
    "Also the 'probably illegal' comment of Evert in a legal court filing has long been discussed off-the-record by me with him. I notified afterwards the AROS devs that I don't feel any reason to be worried and we (AROS) moved on. We don't need other guys taking a stance for AROS and beating on dead horses."
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7824&start=38
  • »26.08.12 - 09:26
    NewSense
    Posts: 1476 from 2012/11/10
    I installed PageStream 4 from the download from PageStream.org but after the installation the program fails to initiate now, and it is even shown as FROZEN in the task manager, as is BME when I try to run that as well. However PageLiner runs OK, though I don't have much use for it.
    I seem to remember I got PageStream 4 to run initially when I installed it once, on my first installation of MorphOS, prior to installing the Ultimate MorphOS CD, but now on my 2nd install it fails as described.
    Not that I am saying that the Ultimate CD is the problem or some conflict it creates with one of the many programs it installs, as on my 2nd FULL install of MorphOS I installed PageStream 4 before I installed The Ultimate MorphOS CD
    I'm running MorphOS 3 on a Mini Mac 1.5GHz
    Anyone else got PageStream 4 working OK on their setup - whatever that might be, which of course would be of interest, as it may be some specifics of the hardware that is the issue here.
  • »10.11.12 - 03:22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=14&topic_id=5875&start=238
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=38&topic_id=8680&start=2
    I doubt it.
  • »10.11.12 - 09:08
  • vox
    vox
    Posts: 524 from 2003/11/25
    magnetic,
    Good to know, so newer Open Source Dopus 5.x is not needed, I can use old 68k CD?
    Beside Ibrowse and Miami, all the rest are titles I will use.
    Lame PC with AmiKit XE
  • »05.01.14 - 11:50
    Yes.
  • »05.01.14 - 15:11
