Napalm on MorphOS
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    I tested a some of CD drives on USB. Under OSX no problem reading the audio CD on the same drive USB, and can even burn the disc. On MorphOS read only data, without write/burn the disc. Jalapeno and Flacapella did not even detect the device on USB.
    _
  • »06.01.14 - 22:08
    Posts: 1516 from 2003/2/24
    You could try to deactivate Simple SCSI setting in Poseidon (see massstorage configuration). Be careful though, I am not exactly sure what it can do. But when enabled it limits what (and how) commands are sent to USB drives.
    [ Edited by itix 06.01.2014 - 23:24 ]
  • »06.01.14 - 22:18
    Reth
    Posts: 18 from 2006/8/27
    Hi altogether,
    just tested this version on Powerbook 1,67GHz G4 with MOS 3.5.1.
    The good news: It is playable (with quite a lot of GFX flickering).
    The bad news: It is not usable. After loading a stored Robot L2 mission (which only works out of the game) the game places randomly a lot of enemy buildings which are not yet even available (according to tech level). Since these buildings cannot be occupied and also not destroyed the mission cannot be completed.
    Anybody any idea on that?
    Bye
  • »20.03.14 - 21:35
    defender
    Posts: 248 from 2011/4/24
    I have not tested this on 3.5.1 but under 3.2 and had no such level problems.
    Ok, you can only load from within the game and the save stats are shown from the upper left
    to bottom right.
    otherwise no faults according to tech level.
    Maybe a corrupt save state ?
  • »21.03.14 - 16:12
    defender
    [quote[After loading a stored Robot L2 mission (which only works out of the game) the game places randomly a lot of enemy buildings which are not yet even available (according to tech level). Since these buildings cannot be occupied and also not destroyed the mission cannot be completed.Quote:
    My game doesn´t even start the mission briefing after the 3.5.1 update.
    But a quick new setup with:
    http://morphos.npage.de/napalm-mos-installer.html
    made the game run again.
    And the robot-level 2 holds no surprises at all.
    greets
  • »21.03.14 - 20:41
    kriz
    Posts: 309 from 2005/10/18
    Oh nice !!!
  • »22.03.14 - 16:32
    Reth
    I took several other attempts. After beginning from first mission it finally worked out. I managed to get into 3rd Level!
    I also had to install exact that archive a 2nd time after I changed some preferences. But for the 2nd Robotlevel I had to restart the entire campaign from the beginning.
    [ Editiert durch Reth 22.03.2014 - 21:04 ]
  • »22.03.14 - 21:00
    Zetec-s
    Posts: 194 from 2008/7/10
    Sorry to dig up an old thread, but I had a go at running Napalm on my G5 Quad last night, using the MorphOS patch and it loads fine but then hangs on the mission briefing screen.
    Anyone got any ideas where I might be going wrong?
  • »28.04.24 - 09:46
    defender
    Hi, i just tested napalm on my iMac G5. It displays play audio jumped after the mission briefing. But the game does not stop. So i changed to the other screen and
    Started playing 🤷🏻‍♂️. Have you extracted the zip file or what kind of patch are you talking about?
  • »30.04.24 - 21:38
