Napalm on MorphOS
    nujack
    Posts: 8 from 2006/9/8
    Thanks for testing and feedback. Can I also get the old version via email please?
    Thank you.
  • »09.12.11 - 18:45
    defender
    Posts: 249 from 2011/4/24
    If someone else is stumbling over our little problem, here is a link
    to the lost file/s. Including audio update to prevent crashes.
    http://morphos.npage.de
    greets
    Holger
    [ Editiert durch defender 10.12.2011 - 16:07 ]
  • »10.12.11 - 12:31
    BalrogSoft
    Posts: 171 from 2006/10/6
    I have followed your instructions, but i can't get it working, after show the intro my MacMini hangs. I have one question, should be changed the cd audio setup?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »22.12.11 - 17:44
    defender
    This is my setup/napalm.prefs file:
    *** Game setup *************************
    ScreenModeType = "ASK"
    VerticalRes = "480"
    PointerFix = "6"
    Language = "english"
    ;*** CD Audio setup *********************
    ;CD_Device = "cd.device"
    ;CD_Unit = "0"
    ;CD_Level = "2"
    ;CD_LevelNr = "8"
    ;CD_Intro = "10"
    ;CD_Menu = "11"
    ;CD_Sides = "12"
    ;CD_Info = "13"
    ;CD_Stats = "15"
    ;CD_Briefing = "16"
    ;CD_Over = "18"
    ;CD_Win = "20"
    *** Amiga Audio setup ******************
    Audio_Driver = "NAPALM_E:Audio.AHI"
    Audio_Device = "audio.device"
    Audio_AudioID = "00000000"
    Audio_Channels = "4"
    Audio_MixFreq = "22050"
    *** Network setup **********************
    Net_Driver = "NAPALM_E:Network.Nullmodem"
    Net_Device = "serial.device"
    Net_Unit = "0"
    Net_Bauds = "14400"
    Net_Initmodem = ""
    Net_DialType = ""
    Net_PhoneCall = ""
    Net_TCPHost = ""
    Net_Port = ""
    Net_NodeNR = "2"
    Net_NodeName = "Player 2"
    Net_Money = "20000"
    Net_TechLevel = "16"
    Net_Mission = "5"
    Net_Side = "1"
    Net_Chat01 = "Yes!!!"
    Net_Chat02 = "Burn, baby burn!"
    Net_Chat03 = "I'm ready!"
    Net_Chat04 = "Hehe, You are wasted!!!"
    Net_Chat05 = "Heya stupid!"
    Net_Chat06 = "NO!"
    Net_Chat07 = "You'll never beat me!"
    Net_Chat08 = "You bastard!!!"
    Net_Chat09 = "You are gonna pay!"
    Net_Chat10 = "Get lost!"
    ==== <end> ====
    I had had this problem in my first tries.
    Check if you have copied the v1.4 files over the original installation.
    Does the screen requester pop up ? if it does then you have installed
    something wrong.
    good luck - and let me know what happens!
    greets defender
  • »22.12.11 - 18:02
    BalrogSoft
    I have checked my prefs file, and i have changed it but it still hangs after intro. But at start, before screen requester appears it show a message that says "can't find store". I have checked md5 value to be sure that files were updated correctly, and it seems to be all ok. I probably forget something, so i will do the third installation.
    [ Edited by BalrogSoft 22.12.2011 - 21:02 ]
  • »22.12.11 - 19:01
    defender
    can't find store, just means that there is no 'store' directory inside your hd installation.
    You only have to create one to get rid of this message. Do you have rtgmaster.library inside
    your libs dir ? if yes, remove it. Because you should not see a requester at the beginning
    of Napalm v1.4 with OS4 emu and overpatched installation.
    give it a try.
    greets
    defender
  • »22.12.11 - 19:48
    BalrogSoft
    I have removed rtgmaster.library but it doesn't work, it fails on the same point after intro and it ask for screen mode, i have installed Napalm again and i have checked prefs file, and it is configured to ask a screen mode, and i have changed it to HIGH and verticalres to 480, then it says "could not open rtg screen.", i think that i must have something that i have installed that must be problematic with Napalm.
  • »22.12.11 - 20:30
    Posts: 12406 from 2003/5/22
    > prefs file [...] is configured to ask a screen mode, and i have changed it to
    "The "ASK" option is for ye olde RTGMaster.library implementation, which is not used any more."
    http://www.amigans.net/modules/xforum/viewtopic.php?post_id=67028#forumpost67028
    ...meaning with the patch applied it always uses HIGH automatically without showing any requester, no matter what you put in the prefs file. So to me it sounds like you haven't applied the patch at all. What's the size of your Napalm executable?
  • »22.12.11 - 20:46
    BalrogSoft
    Maybe this is the reason, because the md5 of CrimsonCrisis executable is exactly the same that Napalm 1.4 update. But i have applied the gpatch manually but it seems that nothing changes. My executable have 130380 bytes.
    [Edited]
    I have executed gpatch with snoopium and logtool, Snoopium shows a fail reading shellppc.prefs, and logtool shows "[OS4KERNEL] Alert: 0x3800e". gpatch doesn't work because it doesn't generate any output file.
    [ Edited by BalrogSoft 23.12.2011 - 00:13 ]
  • »22.12.11 - 21:18
    > Napalm 1.4 update. [...] My executable have 130380 bytes.
    That's proof enough that the patch hasn't been applied. It should be 131,900 bytes as mentioned here. So much for "I have checked md5 value to be sure that files were updated correctly, and it seems to be all ok" ;-)
  • »22.12.11 - 21:31
    BalrogSoft
    Now i have patched the game sucesfully, i have used gpatch from aminet, and now it works perfectly. Thanks to all for your help!
  • »22.12.11 - 22:40
    > needs OS4Emu (if OS4 version of cdplayer.library is used)
    Now also MorphOS-native:
    http://downloads.morph.zone/find.php?find=cdplayer
    http://aminet.net/search?query=cdplayer_lib
  • »18.03.12 - 21:34
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    CDPlayer does not work with usbscsi.device
    _
  • »02.01.14 - 19:49
    defender
    See in Tools Mounter with Powerbook its a "idemacio.device" unit 0
  • »05.01.14 - 09:40
    SKOLMAN_MWS
    USB not IDE!
    _
  • »06.01.14 - 16:14
    defender
    Oh, well i have no Hardware to test that.
    Is your cd drive listet in tools / mounter ?
  • »06.01.14 - 16:57
    SKOLMAN_MWS
    Mount AudioCD-CDDA no problem. Problem is with read CDDA track wav on device USB (read/write error).
    7:24 pm| 0-poseidon.library: Welcome to poseidon 4.4 (13.2.10) © 2002-2010 by Chris Hodges (20090807)!
    7:24 pm| 0-poseidon.library: This is the PPC native MorphOS version.
    7:24 pm| 0-poseidon.library: Event broadcaster started.
    7:24 pm| 0-poseidon.library: Say hello to massstorage.class V4.8 (Supports storage devices via usbscsi.device (MOS)).
    7:24 pm| 0-poseidon.library: Whoah! hub.class V4.4 surprised as Root/external hub base class (MOS).
    7:24 pm| 0-poseidon.library: The door bell rang for hid.class V4.4 (Generic support for human interface devices (MOS)).
    7:24 pm| 0-poseidon.library: New hardware pciusb.device/0 added (MPC5200B OHCI USB 1.1 Host Controller).
    7:24 pm| 0-poseidon.library: Root hub has been enumerated.
    7:24 pm| 20-poseidon.library: Opening pciusb.device unit 1 failed device/unit failed to open (-1).
    7:24 pm| 0-hub.class: Hub with 2 ports successfully configured.
    7:24 pm| 0-hub.class: I'm in love with hub 'PCI Root Hub Unit 0'.
    7:24 pm| 0-hub.class: Detected device 'USB-PS/2 Optical Mouse' at port 1. I like it.
    7:24 pm| 0-hub.class: Detected device 'USB2.0 Hub' at port 2. I like it.
    7:24 pm| 0-hub.class: Hub has added 2 device(s). That'll be fun!
    7:24 pm| 0-hid.class: Using HID Descriptor from initial configuration run.
    7:24 pm| 0-hid.class: HID the road, 'USB-PS/2 Optical Mouse'!
    7:24 pm| 0-hub.class: Hub with 4 ports successfully configured.
    7:24 pm| 0-hub.class: I'm in love with hub 'USB2.0 Hub'.
    7:24 pm| 0-hub.class: Detected device 'USB Keyboard' at port 4. I like it.
    7:24 pm| 0-hub.class: Hub has added 1 device(s). That'll be fun!
    7:24 pm| 5-hid.class: SET_IDLE=0 failed: endpoint stall (4)!
    7:24 pm| 0-hid.class: HID the road, 'USB Keyboard'!
    7:25 pm| 0-poseidon.library: Checking AfterDOS...
    7:25 pm| 0-poseidon.library: PoPo kicks ass.
    7:42 pm| 0-hub.class: New device 'USB2.0 Storage Device' at port 3. Very nice.
    7:42 pm| 0-massstorage.class: Postconfig patchflags 0x0B53 SingleLun ModeXLate RemSupport FixInq36 SimpleSCSI NoReset FixCapacity.
    7:42 pm| 0-massstorage.class: MSD 'USB2.0 Storage Device' LUN 0 available through usbscsi.device unit 0!
    7:42 pm| 0-massstorage.class: Device 'CD-RW CED-8120B' is of CD/DVD ROM type.
    7:42 pm| 0-massstorage.class: Removable Task started.
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    7:54 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    7:54 pm| 0-massstorage.class: Trying to mount unit 0 via MorphOS mount.library.
    7:54 pm| 5-massstorage.class: Command (12 00 00 00 05 00) failed: 2
    7:54 pm| 5-massstorage.class: Fallback: Enabling Fake Inquiry.
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    7:55 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 75 91 00 00 27 10 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 4E 00 00 00 00 00 00 00 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF FF FF 00 00 00 00 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 E3 95 00 00 10 10 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 00 00
    8:48 pm| 0-poseidon.library: Welcome to poseidon 4.4 (13.2.10) © 2002-2010 by Chris Hodges (20090807)!
    8:48 pm| 0-poseidon.library: This is the PPC native MorphOS version.
    8:48 pm| 0-poseidon.library: Event broadcaster started.
    8:48 pm| 0-poseidon.library: Say hello to massstorage.class V4.8 (Supports storage devices via usbscsi.device (MOS)).
    8:48 pm| 0-poseidon.library: Whoah! hub.class V4.4 surprised as Root/external hub base class (MOS).
    8:48 pm| 0-poseidon.library: The door bell rang for hid.class V4.4 (Generic support for human interface devices (MOS)).
    8:48 pm| 0-poseidon.library: New hardware pciusb.device/0 added (MPC5200B OHCI USB 1.1 Host Controller).
    8:48 pm| 0-poseidon.library: Root hub has been enumerated.
    8:48 pm| 20-poseidon.library: Opening pciusb.device unit 1 failed device/unit failed to open (-1).
    8:48 pm| 0-hub.class: Hub with 2 ports successfully configured.
    8:48 pm| 0-hub.class: I'm in love with hub 'PCI Root Hub Unit 0'.
    8:48 pm| 0-hub.class: Detected device 'USB-PS/2 Optical Mouse' at port 1. I like it.
    8:48 pm| 0-hub.class: Detected device 'USB2.0 Hub' at port 2. I like it.
    8:48 pm| 0-hub.class: Hub has added 2 device(s). That'll be fun!
    8:48 pm| 0-hid.class: Using HID Descriptor from initial configuration run.
    8:48 pm| 0-hid.class: HID the road, 'USB-PS/2 Optical Mouse'!
    8:48 pm| 0-hub.class: Hub with 4 ports successfully configured.
    8:48 pm| 0-hub.class: I'm in love with hub 'USB2.0 Hub'.
    8:48 pm| 0-hub.class: Detected device 'TransMemory' at port 2. I like it.
    8:48 pm| 0-hub.class: Detected device 'USB Keyboard' at port 4. I like it.
    8:48 pm| 0-massstorage.class: Postconfig patchflags 0x0342 ModeXLate FixInq36 SimpleSCSI NoReset.
    8:48 pm| 0-massstorage.class: MSD 'TransMemory' LUN 0 available through usbscsi.device unit 0!
    8:48 pm| 0-massstorage.class: Device 'TransMemory' is of Direct Access type.
    8:48 pm| 5-hid.class: SET_IDLE=0 failed: endpoint stall (4)!
    8:48 pm| 0-massstorage.class: Removable Task started.
    8:48 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    8:48 pm| 0-massstorage.class: Trying to mount unit 0 via MorphOS mount.library.
    8:48 pm| 0-hid.class: HID the road, 'USB Keyboard'!
    8:49 pm| 0-poseidon.library: Checking AfterDOS...
    8:49 pm| 0-poseidon.library: PoPo kicks ass.
    8:51 pm| 0-hub.class: New device 'USB2.0 Storage Device' at port 3. Very nice.
    8:51 pm| 0-massstorage.class: Postconfig patchflags 0x0B53 SingleLun ModeXLate RemSupport FixInq36 SimpleSCSI NoReset FixCapacity.
    8:51 pm| 0-massstorage.class: MSD 'USB2.0 Storage Device' LUN 0 available through usbscsi.device unit 1!
    8:51 pm| 0-massstorage.class: Device 'CD-RW CED-8120B' is of CD/DVD ROM type.
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    8:52 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:52 pm| 0-massstorage.class: Trying to mount unit 1 via MorphOS mount.library.
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 01 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0D 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0E 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0F 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 0E 00 FC 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 43 00 00 00 00 00 00 03 24 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 42 00 40 01 00 00 00 FF FF 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 05 0C B8 00 00 19 10 00 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 5A C2 00 00 01 10 00 00
    8:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 43 00 00 00 00 00 00 03 24 00
    8:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 42 00 40 01 00 00 00 FF FF 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:56 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:56 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:57 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF FF FF 00 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 2A 00 22 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 2A 00 00 00 00 00 24 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:57 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 01 60 00 00 00 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 00 00 00 00 00 00 00 15 10 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 00 00 00 00 00 00 00 15 10 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF 00 00 00 00 00 00 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 2A 00 22 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 2A 00 00 00 00 00 24 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 01 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 01 00 00 00 00 00 2A 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 01 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0D 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0E 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0F 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:58 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:58 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    _
  • »06.01.14 - 18:16
    Posts: 1520 from 2003/2/24
    I dont know is this a USB drive specific issue or generic issue in Poseidon. Would need more tests, tests and tests... I believe old analog playing mode would work but it is of course quite useless when USB CD drive dont have audio outputs.
  • »06.01.14 - 18:54
    Btw speaking of audio playback I found out that Fredrik Wikström had updated his cdplayer.library for OS4 a while ago. So I grabbed the latest source and patched my port with his fix and while at it I optimized CDDA playback. Not that it matters anyway because even old 68k code used less than 1% on my G4 Mac but anyway, it is there now.
  • »06.01.14 - 18:56
    defender
    OK, I can see that you drive is visible for poseidon. Do you have to different icons 1 with software and 1 with soundfiles
    on Ambient desktop?
  • »06.01.14 - 19:04
    SKOLMAN_MWS
    I tested a some of CD drives on USB. Under OSX no problem reading the audio CD on the same drive USB, and can even burn the disc. On MorphOS read only data, without write/burn the disc. Jalapeno and Flacapella did not even detect the device on USB.
    _
  • »06.01.14 - 20:08
    You could try to deactivate Simple SCSI setting in Poseidon (see massstorage configuration). Be careful though, I am not exactly sure what it can do. But when enabled it limits what (and how) commands are sent to USB drives.
    [ Edited by itix 06.01.2014 - 23:24 ]
  • »06.01.14 - 20:18
    Reth
    Posts: 18 from 2006/8/27
    Hi altogether,
    just tested this version on Powerbook 1,67GHz G4 with MOS 3.5.1.
    The good news: It is playable (with quite a lot of GFX flickering).
    The bad news: It is not usable. After loading a stored Robot L2 mission (which only works out of the game) the game places randomly a lot of enemy buildings which are not yet even available (according to tech level). Since these buildings cannot be occupied and also not destroyed the mission cannot be completed.
    Anybody any idea on that?
    Bye
  • »20.03.14 - 19:35
    defender
    I have not tested this on 3.5.1 but under 3.2 and had no such level problems.
    Ok, you can only load from within the game and the save stats are shown from the upper left
    to bottom right.
    otherwise no faults according to tech level.
    Maybe a corrupt save state ?
  • »21.03.14 - 14:12
    defender
    [quote[After loading a stored Robot L2 mission (which only works out of the game) the game places randomly a lot of enemy buildings which are not yet even available (according to tech level). Since these buildings cannot be occupied and also not destroyed the mission cannot be completed.[quote]
    My game doesn´t even start the mission briefing after the 3.5.1 update.
    But a quick new setup with:
    http://morphos.npage.de/napalm-mos-installer.html
    made the game run again.
    And the robot-level 2 holds no surprises at all.
    greets
  • »21.03.14 - 18:41
