Napalm on MorphOS
    defender
    Posts: 249 from 2011/4/24
    The Problem belongs to your rtgmaster.library and you really have to install OS4 emulation. On your system
    there should be !no! RTGmaster installed, because it will be generated every time you start the game and if it works
    there will be !no! screen requester the game just simply starts. And you have to update to napalm 1.4 before installing
    the OS4 Napalm patch. By the way the game crashes quiet often, its no fun to play it ~ at
    least on my machine (Powermac3,6 /1,5Gb/Radeon9250-128Mb) good luck and good night!
  • »08.12.11 - 19:58
    Posts: 12557 from 2003/5/22
    > Andreas are you sure you are not useing the rtgmaster.library that is in
    > Napalm/Libs directory? If you delete it the game still works?
    I'm now back on my MorphOS machine and this is what I've found. There's a severe difference between the recent patch version from December 6th and the initial version that was released before:
    * old version: works on MorphOS; needs v1.4 executable as patch base, needs OS4Emu (if OS4 version of cdplayer.library is used), doesn't need rtgmaster.library
    * new version: doesn't work on MorphOS ("ERROR #0010: Unable to open library!"), needs original Napalm CD executable as patch base, OS4Emu on/off makes no difference, rtgmaster.library installed/removed makes no difference
    So I only tried the recent patch version just now and so far I've not managed to make it run on MorphOS. The previous version still runs fine of course with the parameters set as mentioned above. I apologize for the confusion I may have caused.
  • »08.12.11 - 23:52
    > OS4 emulation. On your system there should be !no! RTGmaster installed
    With the new patch version released on December 6th removing rtgmaster.library and switching on/off OS4Emu makes no difference here. Napalm refuses to start, complaining with the mentioned error message.
    > you have to update to napalm 1.4 before installing the OS4 Napalm patch.
    That is required for the old version of the patch. The recent version cannot use the v1.4 executable as patch base but absolutely needs the original Napalm CD executable. Do you really run the most recent executable (132,108 bytes) on MorphOS, not the previous one (131,900 bytes)?
  • »09.12.11 - 00:05
    defender
    I appologize, after your post I took the newest version (from Monday) and it shows the same errors.
    It seems to be a change in the crimsoncrisses file - so we have to take the previous version to run the game.
    Has any of you had the same stability problem when getting into the secound level ?
    sorry for spreading confusion
    defender
  • »09.12.11 - 13:40
    Thanks for clarification.
    Yes. Let's hope there'll be future versions that will work on MorphOS again.
  • »09.12.11 - 14:16
    Miky060
    Posts: 694 from 2003/2/24
    Ok, so now can someone give a link to have the old version of the napalm patch? It's no more available online..
  • »09.12.11 - 15:36
    defender
    I have send it to your e-mail adress.
    Hope you'll get it from your provider.
    greets
    defender
  • »09.12.11 - 17:21
    nujack
    Posts: 8 from 2006/9/8
    Thanks for testing and feedback. Can I also get the old version via email please?
    Thank you.
  • »09.12.11 - 18:45
    defender
    If someone else is stumbling over our little problem, here is a link
    to the lost file/s. Including audio update to prevent crashes.
    http://morphos.npage.de
    greets
    Holger
    [ Editiert durch defender 10.12.2011 - 16:07 ]
  • »10.12.11 - 12:31
    BalrogSoft
    Posts: 171 from 2006/10/6
    I have followed your instructions, but i can't get it working, after show the intro my MacMini hangs. I have one question, should be changed the cd audio setup?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »22.12.11 - 17:44
    defender
    This is my setup/napalm.prefs file:
    *** Game setup *************************
    ScreenModeType = "ASK"
    VerticalRes = "480"
    PointerFix = "6"
    Language = "english"
    ;*** CD Audio setup *********************
    ;CD_Device = "cd.device"
    ;CD_Unit = "0"
    ;CD_Level = "2"
    ;CD_LevelNr = "8"
    ;CD_Intro = "10"
    ;CD_Menu = "11"
    ;CD_Sides = "12"
    ;CD_Info = "13"
    ;CD_Stats = "15"
    ;CD_Briefing = "16"
    ;CD_Over = "18"
    ;CD_Win = "20"
    *** Amiga Audio setup ******************
    Audio_Driver = "NAPALM_E:Audio.AHI"
    Audio_Device = "audio.device"
    Audio_AudioID = "00000000"
    Audio_Channels = "4"
    Audio_MixFreq = "22050"
    *** Network setup **********************
    Net_Driver = "NAPALM_E:Network.Nullmodem"
    Net_Device = "serial.device"
    Net_Unit = "0"
    Net_Bauds = "14400"
    Net_Initmodem = ""
    Net_DialType = ""
    Net_PhoneCall = ""
    Net_TCPHost = ""
    Net_Port = ""
    Net_NodeNR = "2"
    Net_NodeName = "Player 2"
    Net_Money = "20000"
    Net_TechLevel = "16"
    Net_Mission = "5"
    Net_Side = "1"
    Net_Chat01 = "Yes!!!"
    Net_Chat02 = "Burn, baby burn!"
    Net_Chat03 = "I'm ready!"
    Net_Chat04 = "Hehe, You are wasted!!!"
    Net_Chat05 = "Heya stupid!"
    Net_Chat06 = "NO!"
    Net_Chat07 = "You'll never beat me!"
    Net_Chat08 = "You bastard!!!"
    Net_Chat09 = "You are gonna pay!"
    Net_Chat10 = "Get lost!"
    ==== <end> ====
    I had had this problem in my first tries.
    Check if you have copied the v1.4 files over the original installation.
    Does the screen requester pop up ? if it does then you have installed
    something wrong.
    good luck - and let me know what happens!
    greets defender
  • »22.12.11 - 18:02
    BalrogSoft
    I have checked my prefs file, and i have changed it but it still hangs after intro. But at start, before screen requester appears it show a message that says "can't find store". I have checked md5 value to be sure that files were updated correctly, and it seems to be all ok. I probably forget something, so i will do the third installation.
    [ Edited by BalrogSoft 22.12.2011 - 21:02 ]
  • »22.12.11 - 19:01
    defender
    can't find store, just means that there is no 'store' directory inside your hd installation.
    You only have to create one to get rid of this message. Do you have rtgmaster.library inside
    your libs dir ? if yes, remove it. Because you should not see a requester at the beginning
    of Napalm v1.4 with OS4 emu and overpatched installation.
    give it a try.
    greets
    defender
  • »22.12.11 - 19:48
    BalrogSoft
    I have removed rtgmaster.library but it doesn't work, it fails on the same point after intro and it ask for screen mode, i have installed Napalm again and i have checked prefs file, and it is configured to ask a screen mode, and i have changed it to HIGH and verticalres to 480, then it says "could not open rtg screen.", i think that i must have something that i have installed that must be problematic with Napalm.
  • »22.12.11 - 20:30
    > prefs file [...] is configured to ask a screen mode, and i have changed it to
    "The "ASK" option is for ye olde RTGMaster.library implementation, which is not used any more."
    http://www.amigans.net/modules/xforum/viewtopic.php?post_id=67028#forumpost67028
    ...meaning with the patch applied it always uses HIGH automatically without showing any requester, no matter what you put in the prefs file. So to me it sounds like you haven't applied the patch at all. What's the size of your Napalm executable?
  • »22.12.11 - 20:46
    BalrogSoft
    Maybe this is the reason, because the md5 of CrimsonCrisis executable is exactly the same that Napalm 1.4 update. But i have applied the gpatch manually but it seems that nothing changes. My executable have 130380 bytes.
    [Edited]
    I have executed gpatch with snoopium and logtool, Snoopium shows a fail reading shellppc.prefs, and logtool shows "[OS4KERNEL] Alert: 0x3800e". gpatch doesn't work because it doesn't generate any output file.
    [ Edited by BalrogSoft 23.12.2011 - 00:13 ]
  • »22.12.11 - 21:18
    > Napalm 1.4 update. [...] My executable have 130380 bytes.
    That's proof enough that the patch hasn't been applied. It should be 131,900 bytes as mentioned here. So much for "I have checked md5 value to be sure that files were updated correctly, and it seems to be all ok" ;-)
  • »22.12.11 - 21:31
    BalrogSoft
    Now i have patched the game sucesfully, i have used gpatch from aminet, and now it works perfectly. Thanks to all for your help!
  • »22.12.11 - 22:40
    Now also MorphOS-native:
    http://downloads.morph.zone/find.php?find=cdplayer
    http://aminet.net/search?query=cdplayer_lib
  • »18.03.12 - 21:34
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    CDPlayer does not work with usbscsi.device
    _
  • »02.01.14 - 19:49
    defender
    See in Tools Mounter with Powerbook its a "idemacio.device" unit 0
  • »05.01.14 - 09:40
    SKOLMAN_MWS
    USB not IDE!
    _
  • »06.01.14 - 16:14
    defender
    Oh, well i have no Hardware to test that.
    Is your cd drive listet in tools / mounter ?
  • »06.01.14 - 16:57
    SKOLMAN_MWS
    Mount AudioCD-CDDA no problem. Problem is with read CDDA track wav on device USB (read/write error).
    7:24 pm| 0-poseidon.library: Welcome to poseidon 4.4 (13.2.10) © 2002-2010 by Chris Hodges (20090807)!
    7:24 pm| 0-poseidon.library: This is the PPC native MorphOS version.
    7:24 pm| 0-poseidon.library: Event broadcaster started.
    7:24 pm| 0-poseidon.library: Say hello to massstorage.class V4.8 (Supports storage devices via usbscsi.device (MOS)).
    7:24 pm| 0-poseidon.library: Whoah! hub.class V4.4 surprised as Root/external hub base class (MOS).
    7:24 pm| 0-poseidon.library: The door bell rang for hid.class V4.4 (Generic support for human interface devices (MOS)).
    7:24 pm| 0-poseidon.library: New hardware pciusb.device/0 added (MPC5200B OHCI USB 1.1 Host Controller).
    7:24 pm| 0-poseidon.library: Root hub has been enumerated.
    7:24 pm| 20-poseidon.library: Opening pciusb.device unit 1 failed device/unit failed to open (-1).
    7:24 pm| 0-hub.class: Hub with 2 ports successfully configured.
    7:24 pm| 0-hub.class: I'm in love with hub 'PCI Root Hub Unit 0'.
    7:24 pm| 0-hub.class: Detected device 'USB-PS/2 Optical Mouse' at port 1. I like it.
    7:24 pm| 0-hub.class: Detected device 'USB2.0 Hub' at port 2. I like it.
    7:24 pm| 0-hub.class: Hub has added 2 device(s). That'll be fun!
    7:24 pm| 0-hid.class: Using HID Descriptor from initial configuration run.
    7:24 pm| 0-hid.class: HID the road, 'USB-PS/2 Optical Mouse'!
    7:24 pm| 0-hub.class: Hub with 4 ports successfully configured.
    7:24 pm| 0-hub.class: I'm in love with hub 'USB2.0 Hub'.
    7:24 pm| 0-hub.class: Detected device 'USB Keyboard' at port 4. I like it.
    7:24 pm| 0-hub.class: Hub has added 1 device(s). That'll be fun!
    7:24 pm| 5-hid.class: SET_IDLE=0 failed: endpoint stall (4)!
    7:24 pm| 0-hid.class: HID the road, 'USB Keyboard'!
    7:25 pm| 0-poseidon.library: Checking AfterDOS...
    7:25 pm| 0-poseidon.library: PoPo kicks ass.
    7:42 pm| 0-hub.class: New device 'USB2.0 Storage Device' at port 3. Very nice.
    7:42 pm| 0-massstorage.class: Postconfig patchflags 0x0B53 SingleLun ModeXLate RemSupport FixInq36 SimpleSCSI NoReset FixCapacity.
    7:42 pm| 0-massstorage.class: MSD 'USB2.0 Storage Device' LUN 0 available through usbscsi.device unit 0!
    7:42 pm| 0-massstorage.class: Device 'CD-RW CED-8120B' is of CD/DVD ROM type.
    7:42 pm| 0-massstorage.class: Removable Task started.
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    7:54 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    7:54 pm| 0-massstorage.class: Trying to mount unit 0 via MorphOS mount.library.
    7:54 pm| 5-massstorage.class: Command (12 00 00 00 05 00) failed: 2
    7:54 pm| 5-massstorage.class: Fallback: Enabling Fake Inquiry.
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    7:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    7:55 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 75 91 00 00 27 10 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 4E 00 00 00 00 00 00 00 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF FF FF 00 00 00 00 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 E3 95 00 00 10 10 00 00
    8:08 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 00 00
    8:48 pm| 0-poseidon.library: Welcome to poseidon 4.4 (13.2.10) © 2002-2010 by Chris Hodges (20090807)!
    8:48 pm| 0-poseidon.library: This is the PPC native MorphOS version.
    8:48 pm| 0-poseidon.library: Event broadcaster started.
    8:48 pm| 0-poseidon.library: Say hello to massstorage.class V4.8 (Supports storage devices via usbscsi.device (MOS)).
    8:48 pm| 0-poseidon.library: Whoah! hub.class V4.4 surprised as Root/external hub base class (MOS).
    8:48 pm| 0-poseidon.library: The door bell rang for hid.class V4.4 (Generic support for human interface devices (MOS)).
    8:48 pm| 0-poseidon.library: New hardware pciusb.device/0 added (MPC5200B OHCI USB 1.1 Host Controller).
    8:48 pm| 0-poseidon.library: Root hub has been enumerated.
    8:48 pm| 20-poseidon.library: Opening pciusb.device unit 1 failed device/unit failed to open (-1).
    8:48 pm| 0-hub.class: Hub with 2 ports successfully configured.
    8:48 pm| 0-hub.class: I'm in love with hub 'PCI Root Hub Unit 0'.
    8:48 pm| 0-hub.class: Detected device 'USB-PS/2 Optical Mouse' at port 1. I like it.
    8:48 pm| 0-hub.class: Detected device 'USB2.0 Hub' at port 2. I like it.
    8:48 pm| 0-hub.class: Hub has added 2 device(s). That'll be fun!
    8:48 pm| 0-hid.class: Using HID Descriptor from initial configuration run.
    8:48 pm| 0-hid.class: HID the road, 'USB-PS/2 Optical Mouse'!
    8:48 pm| 0-hub.class: Hub with 4 ports successfully configured.
    8:48 pm| 0-hub.class: I'm in love with hub 'USB2.0 Hub'.
    8:48 pm| 0-hub.class: Detected device 'TransMemory' at port 2. I like it.
    8:48 pm| 0-hub.class: Detected device 'USB Keyboard' at port 4. I like it.
    8:48 pm| 0-massstorage.class: Postconfig patchflags 0x0342 ModeXLate FixInq36 SimpleSCSI NoReset.
    8:48 pm| 0-massstorage.class: MSD 'TransMemory' LUN 0 available through usbscsi.device unit 0!
    8:48 pm| 0-massstorage.class: Device 'TransMemory' is of Direct Access type.
    8:48 pm| 5-hid.class: SET_IDLE=0 failed: endpoint stall (4)!
    8:48 pm| 0-massstorage.class: Removable Task started.
    8:48 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    8:48 pm| 0-massstorage.class: Trying to mount unit 0 via MorphOS mount.library.
    8:48 pm| 0-hid.class: HID the road, 'USB Keyboard'!
    8:49 pm| 0-poseidon.library: Checking AfterDOS...
    8:49 pm| 0-poseidon.library: PoPo kicks ass.
    8:51 pm| 0-hub.class: New device 'USB2.0 Storage Device' at port 3. Very nice.
    8:51 pm| 0-massstorage.class: Postconfig patchflags 0x0B53 SingleLun ModeXLate RemSupport FixInq36 SimpleSCSI NoReset FixCapacity.
    8:51 pm| 0-massstorage.class: MSD 'USB2.0 Storage Device' LUN 0 available through usbscsi.device unit 1!
    8:51 pm| 0-massstorage.class: Device 'CD-RW CED-8120B' is of CD/DVD ROM type.
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 9E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    8:52 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:52 pm| 0-massstorage.class: Trying to mount unit 1 via MorphOS mount.library.
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 01 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0D 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0E 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0F 00 00 28 00
    8:52 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 0E 00 FC 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 43 00 00 00 00 00 00 03 24 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 42 00 40 01 00 00 00 FF FF 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 05 0C B8 00 00 19 10 00 00
    8:53 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 04 00 00 5A C2 00 00 01 10 00 00
    8:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 43 00 00 00 00 00 00 03 24 00
    8:54 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 42 00 40 01 00 00 00 FF FF 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:56 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:56 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:56 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:57 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF FF FF 00 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 2A 00 22 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 2A 00 00 00 00 00 24 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:57 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 01 60 00 00 00 00 00 00 00 00
    8:57 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 00 00 00 00 00 00 00 15 10 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BE 00 00 00 00 00 00 00 15 10 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Faking All Mode Pages 0x03-0x05
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command BB 00 FF FF 00 00 00 00 00 00 00 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 2A 00 22 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 2A 00 00 00 00 00 24 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1A 00 01 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 5A 00 01 00 00 00 00 00 2A 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 01 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 02 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 03 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 04 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 05 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 06 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 07 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 08 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 09 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0A 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0B 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0C 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0D 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0E 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 52 01 00 00 00 0F 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Ignoring START_STOP_UNIT command
    8:58 pm| 5-massstorage.class: Simple SCSI: Faking Mode Page 0x05 (Flexible Disk)
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 15 10 00 00 24 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 55 10 00 00 00 00 00 00 28 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 03 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 1B 00 00 00 01 00
    8:58 pm| 5-massstorage.class: Simple SCSI: Filtering SCSI command 01 00 00 00 00 00
    8:58 pm| 5-massstorage.class: Fix Capacity: Correcting number of blocks.
    _
  • »06.01.14 - 18:16
    Posts: 1521 from 2003/2/24
    I dont know is this a USB drive specific issue or generic issue in Poseidon. Would need more tests, tests and tests... I believe old analog playing mode would work but it is of course quite useless when USB CD drive dont have audio outputs.
  • »06.01.14 - 18:54
