Napalm on MorphOS
    zukow
    Posts: 642 from 2005/2/9
    i tested 1.4 and 1.0 version. 1.4 version hangs and 1.0 version require paula direct audio. Maybe 1.1 1.2 1.3 versions run ?
  • »23.05.09 - 18:26
    MarK
    Posts: 641 from 2004/1/25
    and how about to... port napalm to morphos?
    bye, MarK.
  • »29.05.09 - 14:31
    Posts: 2028 from 2003/2/24
    Yes please, but I guess finding the sources is a big task... or does anyone know the original author?
    Anyway I'd think that game could work just fine as it is, if there would be ahi audio module or workaround for it.
  • »29.05.09 - 17:36
    Posts: 12080 from 2003/5/22
    Radoslav Marusa with Cypronia (former Ablaze Entertainment and Cypron Studios).
  • »29.05.09 - 20:52
    kriz
    Posts: 309 from 2005/10/18
    cool, this i must try !!
  • »02.12.11 - 02:32
    XDelusion
    Posts: 602 from 2010/10/27
    As much as I LOVE MorphOS,, the fact that I can not get ImageFX to work right, and the fact that so many PPC RTG games do not work right, really irritates me to no end.
    I am the only guy who can not get sound to work in game when playing Shogo. The menus are fine, but once I start the game the sound vanishes. Likewise, I seem to be the only guy who can't get ImageFX to work either. Strange...
    On the other hand I did get WipeOut to work, and though it does have issues upon startup, it work, so I'm good, but it would be really nice if more than one RTG game worked on here. There are so many titles that I'd love to be enjoying but can not because I can't afford the hardware to run OS 4 on (assuming it does not have compatibility issues as well), or a PPC card at a good price for my classic Amiga(s).
    TOTAL BUMMER!
    So yes, I for one agree, it would be grand to get this game running right under MorphOS. I wonder what's holding it back? If only the sources had been released....
  • »02.12.11 - 05:06
    This is not true, and you know it.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7754&forum=10&start=11
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5995&forum=16&start=1
    I'm sure it's more than one.
    OS4 has worse compatibility to those games than MorphOS.
    Nothing. Missed my posting above?
  • »02.12.11 - 11:30
    It has been accomplished:
    http://os4depot.net/?function=showfile&file=game/strategy/napalm.lha
    Ooooh! \o/ Wow...aaaah... finally! :) Seems to work o//
    But...but... network is disabled :( It is pretty essential thing to fully enjoy the game. Wake me up again when it's done too ;) /me continues to wait... but probably takes little single player game meanwhile :P
  • »02.12.11 - 17:45
    > network is disabled :( [...] Wake me up again when it's done too ;)
    New version from today (same link) has written "Included experimental serial network driver (not tested)" in its changelog.
  • »06.12.11 - 13:48
    Miky060
    Posts: 694 from 2003/2/24
    Here it does not works. Looking Snoopium it seems it looks for picasso.library..
    In every case I get a window that says "ERROR #0010: Unable to open library!"
    [ Edited by Miky060 06.12.2011 - 14:38 ]
  • »06.12.11 - 14:35
    Maybe you missed the "OS4Emu" part in posting #8?
  • »06.12.11 - 14:42
    > OS4emu is only needed for CD audio. I didn't use that cdplayer.library at all.
    I don't use CD audio either but here patched Napalm refuses to start and complains that it can't load the lib if OS4Emu is not running.
    > do you have rtgmaster installed?
    Is that really needed with the patched version? The patch author said he removed the RTGMaster dependencies:
    http://www.amigans.net/modules/xforum/viewtopic.php?post_id=63637#forumpost63637
    http://www.amigans.net/modules/xforum/viewtopic.php?post_id=67008#forumpost67008
  • »06.12.11 - 14:59
    Miky060
    I have the morphos native rtgmaster.library in my sys:Libs/
    Tryed also to launch PatchLoadSegOS4 before launching Napalm, but nothing changes..
  • »06.12.11 - 15:09
    Then I'm puzzled, sorry.
  • »06.12.11 - 15:15
    defender
    Posts: 248 from 2011/4/24
    Hey there, I have installed Napalm and direct after that I installed the 1.4 Patch from the AmigaFuture Page (just copy all files from the lha into the Napalm dirctory). On my Morphos 2.7 there is no RTG Master installed. After that I installed the Napalm OS4 Installer (delete the word "abort" command in row 16, and change the info to use the standart programm Morphos:c/installer). Well that's it. Ok for the sound you have to edit the NAPALM.PREFS file with ED so that row 29 (Audio_Driver) shows NAPALM_E:Audio.ahi. Additional you have to set Vertical sync inside the game (ESC while playing and then into the game_control menue). Until now I've played the first mission and that was quit impressive against
    my original A1200 with all its addons.
    greets defender
  • »06.12.11 - 17:52
    Thanks for confirming that RTGMaster isn't required any longer.
  • »06.12.11 - 18:23
    Miky060
    Andreas are you sure you are not useing the rtgmaster.library that is in Napalm/Libs directory? If you delete it the game still works?
  • »06.12.11 - 20:57
    Yes, I have no rtgmaster.library there. However, I have one located in libs: but I'm not in reach of my MorphOS machine right now so cannot test what happens if I delete it from there. Have a look above where defender just said in this thread that he doesn't have rtgmaster.library installed and yet Napalm runs.
  • »06.12.11 - 21:03
    nujack
    Posts: 8 from 2006/9/8
    Miky060,
    I receive the same Error-message on my MacMini with MOS2.6. Strange. Which library is needed?
    Snoopium tells something about Picasso96API and rtg.library.
    Any hints are welcome.
  • »08.12.11 - 15:43
    defender
    The Problem belongs to your rtgmaster.library and you really have to install OS4 emulation. On your system
    there should be !no! RTGmaster installed, because it will be generated every time you start the game and if it works
    there will be !no! screen requester the game just simply starts. And you have to update to napalm 1.4 before installing
    the OS4 Napalm patch. By the way the game crashes quiet often, its no fun to play it ~ at
    least on my machine (Powermac3,6 /1,5Gb/Radeon9250-128Mb) good luck and good night!
  • »08.12.11 - 21:58
    I'm now back on my MorphOS machine and this is what I've found. There's a severe difference between the recent patch version from December 6th and the initial version that was released before:
    * old version: works on MorphOS; needs v1.4 executable as patch base, needs OS4Emu (if OS4 version of cdplayer.library is used), doesn't need rtgmaster.library
    * new version: doesn't work on MorphOS ("ERROR #0010: Unable to open library!"), needs original Napalm CD executable as patch base, OS4Emu on/off makes no difference, rtgmaster.library installed/removed makes no difference
    So I only tried the recent patch version just now and so far I've not managed to make it run on MorphOS. The previous version still runs fine of course with the parameters set as mentioned above. I apologize for the confusion I may have caused.
  • »09.12.11 - 01:52
