Problem trying to run 3.1 on Peg1
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    First post in quite some time. Hope you're all well.
    It's been a long time since I used MorphOS but finally have a bit of time on my hands and thought I'd give 3.1 a whirl on my old Peg1.
    Anyway, when I try to follow these instructions:
    http://www.morphos-team.net/installation
    Turn on your Pegasos 1/2 :)
    Press escape on the keyboard until you reach the Open Firmware prompt
    I get:
    error: could not open keyboard for console input
    Now this rings a vague bell from years back and I think it was quite a common issue at one point. Unfortunately, having been away from anything Amiga related for so long, I feel like a complete noob.
    Anyone recognise this and know how to get around it?
    Cheers,
    Robert.
    [ Edited by Robert 26.12.2012 - 14:06 ]
    Robert.
  • »26.12.12 - 12:04
    Posts: 3321 from 2003/3/5
    Afair you need a PS/2 keyboard.
  • »26.12.12 - 12:50
    Posts: 1090 from 2004/9/23
    Yes, an USB Keyboard is not working.
    Geit
  • »26.12.12 - 13:14
    Robert
    Thank you both.
    I shall have to have a rummage in the loft! :-o
    Robert.
  • »26.12.12 - 15:39
    Robert
    OK, found a PS/2 keyboard and now get the "ok" prompt but when I type in:
    > boot /ide/cd/bootpeg1.img
    I get:
    error: data stack underflow
    error: error while trying to load or boot
    -EDIT-
    some further info:
    ls /pci/ide/cd
    returns:
    Root dir: " " flags=0x2 extent=0x15 size=0x800
    220733440 MORPHOS-.ISO
    -EDIT 2-
    OK, think I'd burnt the CD wrong. I now have it trying to boot from CD but it boots into my existing MOS1.4 set up after a restart.
    Any ideas?
    [ Edited by Robert 26.12.2012 - 19:07 ]
    Robert.
  • »26.12.12 - 15:56
    ausPPC
    Posts: 543 from 2007/8/6
    Just to make sure the CD is booting as expected, unplug the hard drive(s).
    Is starting over with a fresh / alternate hard drive an option for you? If you have an adapter, you could also plug the existing drive in via USB after the CD has booted and still install to it...
  • »26.12.12 - 18:42
    Posts: 2565 from 2003/2/24
    A slighly "easier" way.
    Copy the 3.1 bootpeg1.img onto your boot: partition (name it boot3.1.img)
    Copy the ISO either to your boot or sys partition (might be the same depending on setup)
    Go back to OF-prompt and type :
    "boot boot3.1.img bi dh0:morphos3.1.iso" (or whatever the name&path to the ISO is).
    You should be able to install/update from there.
  • »26.12.12 - 18:51
    Robert
    OK, thanks.
    I think this might be where the problem is. The CD spins up and seems to be doing something, then the VGA output stops, as though the Peg1 has reset or something.
    Robert.
  • »26.12.12 - 19:29
    Robert
    @Kronos:
    I have a "bootimg" partition (which I think is the boot partition) and a "Morphos" partition (which I think is the sys partition). Should I copy the ISO to the Morphos partition?
    Robert.
  • »26.12.12 - 19:46
    redrumloa
    Posts: 1424 from 2003/4/13
    Robert,
    Open a new shell window and type:
    sys:
    Then hit enter. If it switches to MorphOS:> then yes, that is where you copy the ISO. :-)
  • »26.12.12 - 19:52
    Do as red says ;)
    And make sure that the renamed boot3.1.img is on the same partition as the currently used bootpeg1.img.
  • »26.12.12 - 20:01
    Robert
    sys:
    Yeesh! I really have been away a long time; took me five minutes just to find the CLI!
    Robert.
  • »26.12.12 - 20:04
    Robert
    OK, after copying the bootpeg1 image to my bootimg partition, renaming it and then copying the full ISO to the system partition, entering:
    gives me the little spinning cursor for a second, followed by:
    Quark/OpenFirmware
    System: <bplan,Pegasos> Rev <1A>
    etc.
    with a blinking cursor underneath but no further progress.
    Robert.
  • »26.12.12 - 20:16
    redrumloa
    Do you have an IRC client on another computer? if so, I suggest you aim it to:
    Server - irc.freenode.net
    Channel - #MorphOS
    Ask for help in there IMO. Give it a little time for a reply, but someone will reply.
  • »26.12.12 - 20:33
    Robert
    redrumloa,
    Channel - #MorphOS
    I've never really used IRC but will try to set it up on my Mac. Cheers.
    Robert.
  • »26.12.12 - 20:46
    CountRaven
    Posts: 566 from 2007/12/10
    Have you downloaded your ISO correctly? I have similar problems and I think it was due to a bad ISO. Double check your ISO and double check your burning method. The usual Disk Utility will do the burning trick on a Mac.
    Also, have you got a second CD / DVD Drive connected on your Peg1? If yes try to boot form this one.
  • »27.12.12 - 23:18
    ausPPC
    Robert, providing it shows up in open firmware you could also copy all the files on the iso to a flash drive and try booting from that instead.
  • »28.12.12 - 02:04
    CountRaven
    Hmm do not think that Peg1 would be able to read anything USB related on the OF.
  • »28.12.12 - 02:24
    redrumloa
    Just for the record, does this Peg1 have April2 fix?
  • »28.12.12 - 10:36
    CountRaven
    Good question, but even without the fix, morphos would boot -I suppose-.
    [ Edited by CountRaven 28.12.2012 - 18:01 ]
  • »28.12.12 - 16:00
    Robert
    Sorry for the delayed response folks. Time off work turned out to be much busier than expected.
    CountRaven,
    It certainly seems to be OK, i.e. it contains a whole bunch of files, including bootpeg1.img.
    Yeah, I hadn't burnt the image correctly the first time but I think I did 2nd time around.
    No but I might have another CD drive lying around so will have a look later (not at home right now).
    Robert.
  • »03.01.13 - 14:08
    Robert
    @red:
    Not 100% but I don't think so. It's one of the early ones.
    Robert.
  • »03.01.13 - 14:10
