Ram modules compatibility on PegII
    Miky060
    Posts: 694 from 2003/2/24
    Hi all!
    Why don't we make a list of tested/compatible Ram modules on PegII? .. as proposed for GFX cards. We could do a unique list with all Pegasos compatible hardware.
    However these are my first tests with PegII and Ram:
    - Exilir 256 MB DDR266 CL2.5 module: it works OK.
    - Star Ram 512Mb DDR266 module: it works OK.
    - 2 X Star Ram 512 modules: 1GB Ram, they work OK.
    - 1 Exilir 256 MB DDR266 CL2.5 module + 1 Star Ram 512Mb DDR266 module: Systems see only 512MB of Ram and not 768!!!!
    Why!?
  • »09.01.04 - 13:42
    Posts: 159 from 2003/10/24
    This ram works wonderfully.
    http://www.kreton.com
    Kreton/Elixir 512MB PC3200
    DDR 400MHz/PC3200
    --Mithalas
  • »09.01.04 - 14:04
    downix
    Posts: 105 from 2003/2/10
    @Miky060
    Probably because they're not matched pairs.
    Nate Downes
    Genesi SARL
  • »09.01.04 - 14:13
    MaSC
    Posts: 63 from 2003/12/1
    Dane-Elec 128MB 333mHz DDR works fine here.
    As a side note 128mb 2100 Kingston Value RAM DID NOT WORK for me however wether the make is incompatable or this particular module was faulty I can not say. Either way I am aiming for a refund :)
  • »09.01.04 - 17:44
  • -D-
    -D-
    Posts: 118 from 2003/5/1
    Dane-Elec, DDR 266, 256MB (uses NANYA chips, which kick ass)
  • »09.01.04 - 19:09
    Druideck
    Posts: 82 from 2003/5/6
    AZENRAM 256 MB DDR works great!
  • »09.01.04 - 19:15
    MaSC
    by MaSC on 2004/1/9 19:44:43
    Just checking something relevent to this module, when I do a `avail h' in shell I get:
    Type Available In-Use Maximum Largest
    fast 22.8M 79.4M 102.1M 18.2M
    total 22.8M 79.4M 102.1M 18.2M
    This looks like only 102mb of the 128 available is being detected or am I reading this wrong?
    Thank-you
    Mark Cheetham
  • »15.01.04 - 22:51
    nels664868
    Posts: 117 from 2003/12/28
    Hi MaSC
    'Avail h' shows the memory status after the OS is loaded.
    The 25.9M that is missing is used by morphos
    The avail command on my peg2 with 512M is:
    Type Available In-Use MaxImum Largest
    fast 442.2M 39.8M 482.1M 433.5M
    total 442.2 39.8M 482.1M 433.5M
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »15.01.04 - 23:13
    Granada
    Posts: 32 from 2003/12/30
    512MB PC333-DDR Mustang CL2,5 also works fine.
    Granada
    Mac Mini G4, 1.5GHz, MorphOS 2.7
  • »16.01.04 - 09:10
    liquidbit
    Posts: 407 from 2003/10/12
    My TwinMOS 512MB DDR/333MHz module works fine on my PegII!
  • »16.01.04 - 09:48
