setting up printing hp laserjet cp1525nw
    amiga4001
    Posts: 454 from 2006/11/16
    I want to set up printing on my powerbook with mos 3.0
    I have a wifi hp laserprinter a laserjet cp1525nw.
    I filled in the ip adres and set the printerprefs to netprinter.device unit 0 and to a colourlaserjet.
    I then tried to print a pdf with the integrated pdf viewer set to postscript but nothing reaches the printer.
    The ip adres is correct as I can reach the printer through owb.
    I also tried netprinter.device unit 1 same result.
    Also tried a hpdeskjet dame result.
    Any help to get it going?
  • »04.07.12 - 17:53
    Posts: 2204 from 2003/2/24
    Change output from PS: to PRT: in pdf viewer and try then?
    [ Edited by jPV 04.07.2012 - 22:05 ]
  • »04.07.12 - 18:04
    amiga4001
    Ok that was the problem thanks!
  • »04.07.12 - 18:19
