Impossible access to the contain of a ntfs hard drive
    Brumiga
    Posts: 252 from 2004/4/3
    A friend has given to me the hard disk of an old laptop pc dead. It size is 40 gb, 37 gb in ntfs formated. I have bought an external usb box and I have placed the hard disk inside. I plug it to the pegasos 2, it is reconised by poseidon, with mounter I can mount it without problem. But if I try to access to his contain I obtain the following error message from ntfilesystem.
    http://img.imagesia.com/fichiers/y/ntfilesystemerror_imagesia-com_yge_large.png
    In a first time I have though that the problem came from ntfilesystem3g. It wants filesysbox.library present in morphos 3.0 and deviceio.library which should be present in morphos 2.5, but I did not find it there. I have renamed ntfilesystem present in mossys:l to try to use ntfilesystem3g. But then mounter does not detect the type of partition. In ntfilesystem3g documentation it is said to edit the pref file filesystems.conf present in envarc:sys. But I do not have this file. If an user has this file could it be possible to paste the contain in his reply ? Otherwise is there an other thing to do so that the contain of this hard disk should be accessible in read as in write ?
    Brumiga
  • »30.06.12 - 14:23
    stephen_robinson
    Posts: 746 from 2007/4/22
    The obvious thing would be to attach it to a WIndows based computer?
  • »30.06.12 - 17:13
    Leif
    Posts: 111 from 2006/5/31
    Ok.
    You are not running the 3G version if you got that requester.
    What version of MorphOS are you using ?
    NTFS-3G requires 3.0. Maybe it isnt clear in the readme.
  • »30.06.12 - 17:34
