MorphOS Developer
Posts: 622 from 2003/2/24
dake,
If I have used a SSD drive for a while the writing performance will be slower.
But let say you have this 100Gb disk only 50% full, then if you write a 1Gb file on it and overwrite this file 49 times, wouldnt 49GB be marked as free? And get full write performance again:)
It's way more complex than that: https://en.wikipedia.org/wiki/Write_amplification
Also, some controllers have intelligent technology that reduces the write amplification during normal use, and thus reduce (often totally remove) the need to TRIM.
Sandforce chipset is good example of this.
