APDF fonts
    dake
    Posts: 204 from 2007/9/14
    When I try to read some PDF's there will only be strange characters, APDF tries to open fonts with some strange names xxxxxTTE13843E8t00.ttf xxxxTTE1386650t00.ttf.
    Any solution for this?
  • »08.09.10 - 06:11
    Divinity
    Posts: 518 from 2009/9/8
    @dake
    same problem here: I have these problems with all *.pdf at 1200 DPI
  • »08.09.10 - 06:39
    Brumiga
    Posts: 276 from 2004/4/3
    Hello,
    In the settings of apdf I have added all the truetype fonts from m$ downloaded for owb. I have also added from mossys:fonts/_ttf the dejavu family and the vera family fonts. Try both my solution, it may work.
    Be nevertheless warned that some truetype fonts presents in some pdf documents are paying ones, so if they are absent there is no solution.
    Brumiga
  • »08.09.10 - 18:25
    dake
    @Brumiga
    Thanks but no luck:(
    Now I'm at home and the correct filenames that Apdf I/O Server looks for is "GOCSXU+TTE1386650T00.ttf", "LWMNYZ+TTE13843E8t00.ttf" and "ANAPBW+TTE1294608t00.ttf".
    I believe that this kind of font names does not exist as files, instead Apdf should collect this from an existing font.
    Can anyone please explain.
    @Andreas_Wolf
    Where is my links!
    Is the Morphzone link collector down! :)
  • »09.09.10 - 05:47
    Posts: 12543 from 2003/5/22
    > @Andreas_Wolf
    > Where is my links!
    Unfortunately, I've none on that problem. My only problem with garbled fonts in APDF is with some of the PDF files which have their fonts embedded. As a workaround I use the online Google Docs Viewer.
  • »10.09.10 - 00:57
    Another approach, even nicer as it doesn't require the PDF file to be online:
    http://andreasgal.com/2011/06/15/pdf-js/
    https://wiki.mozilla.org/PDF.js
    Works fine in OWB (may be neccesary to switch pages before content becomes visible).
  • »18.06.11 - 14:20
    dake
    Thanks Andreas!
    very interesting project!
    But there is not many pdf:s that can be loaded with this, maybe some OWB issue but I don't think soo.
    When I download the https://github.com/andreasgal/pdf.js/tarball/master version this couldn't render at all even if you switch pages, but the https://github.com/andreasgal/pdf.js/tree/gh-pages version could render with some strange characters:(
    Do you manage to use this select file button in the submittet link to view a pdf?
    Anyone else having total success with this?
  • »19.06.11 - 09:14
    This project has only just been started so expect it to improve over time.
    Yes, same here. Seems OWB compatibility got broken from the older version with strange character rendering to the newer one with no rendering at all. But as it's all in a state of flux let's monitor the development and try new versions from time to time to see if OWB compatibility returns.
    No, I don't. Sorry for having been not specific enough. I just meant to refer to the rendering of the one default document. It seems that as of now we have to pre-specify in the script the document we want to show.
  • »19.06.11 - 11:29
    dake
    Thanks for the clarification.
    Agree
  • »19.06.11 - 13:05
    Found another one with the same approach:
    http://trapeze.xyrka.com
    http://code.google.com/p/trapeze-reader/
    http://blog.xyrka.com/?p=43
    OWB on MorphOS: doesn't work (white sheet)
    TenFourFox on Leopard: doesn't work (crash)
    Safari on Leopard: works
  • »23.06.11 - 09:48
    > Yes, same here.
    Works again in OWB :-)
    ...and some more information:
    http://blog.mozilla.com/cjones/2011/07/03/pdf-js-first-milestone/
    ...as well as a new homepage with new online demo:
    http://mozilla.github.com/pdf.js/
    Edit: updated github link to new location
    [ Edited by Andreas_Wolf 15.11.2011 - 13:46 ]
  • »11.07.11 - 00:22
    Divinity
    news about a new PDF viever in MorphOS2.x ?
    I'd like it A LOT !!! :)
  • »20.07.11 - 19:29
    mobydick
    Posts: 179 from 2004/2/26
    May be, it is stupid question, but... How to install it?
    [ Edited by mobydick 08.08.2011 - 19:21 ]
    peguser.narod.ru
  • »08.08.11 - 13:20
    > How to install it?
    Click the first link in posting #7 to download the most recent version from the repository. Extract the archive to where you like.
    For usage:
    Open from within OWB the file /web/viewer.html and then select your own local PDF file from there (yes, the 'select file' button actually works with the most recent version as opposed to the release version from one month ago that is also in the current online demo).
  • »08.08.11 - 21:08
    mobydick
    Thank you,
    Yes, the button works. Unfortunately, the script renders pages very slow. Also, it can not open most of my pdf files.
    peguser.narod.ru
  • »09.08.11 - 17:45
    Of course it's slower than a natively compiled application like Apdf, after all it's a script executed by an interpreter (at least as long as we've no JavaScript JIT on MorphOS).
    Actually, it can open all of my PDF files, but most of them are not displayed flawlessly yet ;-)
  • »09.08.11 - 18:19
    mobydick
    Happy man :) Usually I see *nothing*. Well, let wait for new versions...
    peguser.narod.ru
  • »10.08.11 - 05:41
    After it finishes loading a new PDF (watch the CPU load) step one page forward, also after display size change. Does that change anything for you? For example jacadcaps' dual boot guide is rendered rather nicely here (it has some very small glitches though).
  • »10.08.11 - 08:45
    mobydick
    I tried this way without success. But now i can't chack anything 'coz i have no access to my Pegasos. I'll try it at sunday.
    peguser.narod.ru
  • »10.08.11 - 17:31
    > news about a new PDF viever in MorphOS2.x ? I'd like it A LOT !!! :)
    It seems MorphOS 3.0 will have it:
    "New pdf viewer too, the layout looks a lot better than the current one. If based on a recent version of Poppler as the source, it should incorporate changes form xpdf 3.02 (ie support for pdf v1.6 and 1.7) too!"
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8121&forum=9
  • »13.11.11 - 15:35
