Yam and OWB empty screens with LMB
    defender
    Posts: 249 from 2011/4/24
    Hi there,
    does one of you know a way how to get Yam to work correctly with OWB1.14 (and below)?
    Every time I dobble klick on a link in my mails it opens an empty page. After dobbleklicking
    again on that link - the page opens correctly.
    Thats not a great problem ... but I don`t like this behavior, and would happy for a solution to it.
    Thanks a lot
  • »20.09.11 - 14:47
    Oli716
    Posts: 16 from 2011/9/18
    seems not to be a common problem, i'm using Yam 2.6p1 and OWB 1.14 and everything works fine when double clicking links in mails. OWB opens the links immediatly.
    Maybe a reinstall does help?
  • »20.09.11 - 15:04
    Posts: 1099 from 2004/9/23
    Sounds like the OpenURL stuff is missconfigured.
    Open OpenURL prefs and use the context menu to reset preferences for mail and browser.
    Geit
  • »20.09.11 - 15:16
    defender
    @ geit
    Arexx-commands
    Show
    Screentofront
    open name "%u"
    open name "%u" newpage
    @ OLI
    I also use 2.6p1 and thats my only problem with it.
    Do you use the original Morphos arexx?
    i think i played with the os 3.9 version
    in order to run Tubexx .. as far as I remember.
  • »20.09.11 - 16:14
    defender
    Thank you @ geit
    it took me a while to find the button (without a name) in right corner.
    @ OLI Thanxs for for your help, too!
  • »20.09.11 - 17:57
