Batch Factory A Front End for AREXX scripts
    osco
    Posts: 680 from 2009/10/20
    # Batch Factory Configuration File - Version 1.0
    # Maximum Number Of Files Allowed In List
    MAXFILES=999
    # Path & Name Of Program To View Pictures
    PICVIEW=SYS:Applications/ShowGirls/ShowGirls
    # Path & Name Of Program To View Text Files
    TEXTVIEW=SYS:Utilities/Multiview
    # Path To Save Temporary Image Files
    TEMPPATH=RAM:
    Opens on a SMALL sceen can the above confiuration be changed to a full screen? 8-)
  • »18.08.11 - 06:58
    Posts: 2565 from 2003/2/24
    What exactly opens on a small screen ? (and is it really a screen or just a window ?)
    You might go into the MUI-Settings of the Window/Screen (which I assume would eiether be ShowGirls or MultiView) and change the screen there. Hit "Save" and it should work next time.
  • »18.08.11 - 08:28
