No sound after running a demo
    ausPPC
    Posts: 543 from 2007/8/6
    After running Metro Police on my Efika I lose sound - even after a reset and powerdown. I had the same issue with 2.5 just before I installed 2.6 - the fresh install fixed the problem. Is this likely to be a bad config file that I can just delete? How can I restore audio output?
  • »02.11.10 - 10:03
    Posts: 1383 from 2010/1/6
    Do you have sound if you start from a "virgin" MOS-installation?
    If yes: check the preferences (AHI-Channel, ......) or delete the propper files in env-archive:
    If not: disconnect your Efika from electric source, dismount the backup-battery, wait 5 minutes, boot your Efika and insert battery (during Efika is running) -> This may help (but no guaranty).......
    [ Editiert durch Amigaharry2 an 2010/11/2 18:27 ]
  • »02.11.10 - 13:27
