Network speed when copying files
    dake
    Posts: 204 from 2007/9/14
    If I for example is downloading alot of files with MLDonkey and look in the Network Statistics window I can enjoy a very high download speed. But if I now start to copy some large files with Ambient I can see a very large drop in the recieve speed.
    Mac mini 1.83GHz, MorphOS 2.5
    This is not a disaster, but i suppose we want MorphOS to be perfect!
    Big Thanx to all developers of MorphOS!
  • »29.07.10 - 16:12
  • rms
    rms
    Posts: 602 from 2004/11/27
    @ dake
    I think I experience this also, even on the Pegasos2 not only on Mac Mini. When starting the copy then it says something like "Buffering..." or so and it takes quite some time before it starts the copy process. Don't know why this happens...
  • »30.07.10 - 05:46
    dake
    @rms
    Hmm, I don't believe we talk about same thing here.
    Sounds like you should defrag your partitions or increase buffers for SFS in system settings.
  • »30.07.10 - 10:05
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    I have noticed that copying files from newtork drive with FTP was super slow. Not tried with just normal file copy. Will try over weekend and report back
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »30.07.10 - 10:11
  • rms
    rms
    @ dake
    I thought defragmentation doesn't existe anymore with SSD drives? or isn't that the case? and buffers are set to 2048 for all partitions as well as in SFS settings buffer lines = 128 and read ahead buffer = 32768 (these settings where suggested by the SFS developper some years back)
  • »30.07.10 - 10:48
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    The buffering phase allocates memory for the copy, and computes the number of files and total size. If this phase takes long, it means you really have a slow access to the files (or possibly heavy fragmentation like gdanko suggested).
  • »30.07.10 - 13:13
  • rms
    rms
    @ Fab
    I dont think it's a fragmentation problem, as I checked the hd's with defrag and I had all in all about 1 % of fragmentation. I rather think it's again a LAN problem due to perhaps slow access to the files on those partitions...
    Buh.. these LAN problems are driving me crazy! I still can't use my MacMini's because of this! I don't know neither if this is an Envoy3 problem or a device problem as with the Pegasos's it seems to work but not the MacMini's.
    Also I don't know how to setup a LAN with some other software than Envoy3, something like I have with Envoy3, which is: one Pegasos acts as a server and several partitions of the servers HD are mounted automatically during stratup on the clients and these partitions are available just like if they where local partitions.
    If you can help me with this, it would be great. As I use MorphOS professionnaly and there are 4 people working every day 8 hours, I need to be shure that there want occur any problems, like data corruptions, or if coping a lot of small files that the LAN hangs, or...
  • »02.08.10 - 08:07
