Posts: 1178 from 2003/3/13
dake wrote:
If you want a volume to remember it's view, be sure to have a disk.info in the volumes root directory. If you want to snapshot a window view you must have a directoryname.info file to that directory.
Of course, I should have realized about it, thanks for the tip. Somehow, I supposed that the ".info" file sould be automatically created upon snapshotting.
As the snapshot function would no nothing without the ".info" files, it should be made unavalaible for the user. But perhaps the files' absence is not easy to check, or would have an unwanted cost.
