USB Eject
    dake
    Posts: 204 from 2007/9/14
    If I rightclick and select Eject on an USB icon nothing happens.
    If I use Eject tool in screenbar the USB icon is correctly removed from desktop and I can't access the volume.
  • »09.05.10 - 08:48
    Jambalah
    Posts: 820 from 2008/3/30
    If you try the shortcut, with usb icon selected, execute command window will appear.
    In fact it's the same shortcut for both.. Next fixing for 2.5 =)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »09.05.10 - 16:08
  • rms
    rms
    Posts: 606 from 2004/11/27
    @ dake
    I don't understand why you would need to do such? This seems rather to be needed on windoof but I dont think on MorphOS... Am I wrong? did I miss something?
  • »10.05.10 - 03:15
    dake
    @rms
    You are totally right, but if there is a eject in the menu, it should work properly, and sometimes i found this eject very useful when playing with alot of partitions.
  • »10.05.10 - 05:09
