Mounting HDF files
    Qwert44
    Posts: 22 from 2009/11/16
    Might be a rookie question, but I am just warming up my Amiga knowledge again... :)
    I have some older classic Amiga HDF files stored on my MAC --> I plan to copy them onto my MacMini Morphos 2.4 and use some 68k stuff & data from my classic environment.
    What is the easiest way to mount those HDFs in MorphOS? Or better to ask: what is the easiest way to get the content of those .HDF files?
    many thanks...
  • »18.11.09 - 12:49
    March
    Posts: 91 from 2003/7/30
    Run Utilities/FileImageCtrl tool, drag&drop hdf file to the FileImageCtrl window (or click insert and select the hdf file). Then run Utilities/Mounter tool, select the fileimage.device - your partitions should be listed in the main window. You can mount each partition manually by clicking 'Mount'.
    [ Edited by March on 2009/11/18 17:51 ]
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »18.11.09 - 15:50
    Qwert44
    thanks a lot, excellent, that works! :)
  • »18.11.09 - 16:29
    beworld
    Posts: 683 from 2010/2/10
    It's possible to have file .ct / .cs or .cd to translate this tool in french ?
    Thanks
    BeWorld
    My MOS ports
  • »01.04.10 - 08:31
