DrawStudio still unusable
    Travis_H
    Posts: 167 from 2009/12/17
    The DrawStudioPatch did, indeed, stop the crashing when accessing menus, but the program is still virtually unusable. Here's why:
    1. The most important part (for me) of the program are the attributes you can assign to objects. Any part of an object can be a solid color, a gradient, a pattern, a bitmap or nothing at all. Unfortunately, under MorphOS the lists of colors, gradients, and patterns are empty. Even if you load the palette you want, it's only available that one time. For example, try to create a new gradient and you'll discover there are no colors to choose from! This makes that function useless!
    Can anyone think of why this is happening with DrawStudio? It works flawlessly under Amithlon, so emulation shouldn't be a problem.
    Travis
  • »20.12.09 - 14:24
    Posts: 3355 from 2003/3/5
    Since noone in the MorphOS Team is actually using the said application, we can only try to fix what is reported broken. Anyway, I'll see what I can do about it.
  • »20.12.09 - 21:20
