Gloom Deluxe shows start picture but hangs
    BalrogSoft
    Posts: 171 from 2006/10/6
    I know that is not listed as a compatible game, but i gave a try and it shows start picture, but then it hangs, somebody tried to run Gloom Deluxe or another versions on MorphOS?
    Another question, what is the best way to analyse and patch games to run on MorhpOS, there are any way to active log of Trance and see where is hanging? What disassembler and reassembler are the best to patch the game?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »23.10.09 - 17:36
    Henes
    Posts: 507 from 2003/6/14
    First of all, when analysing 68k issues, you should better disable Trance completly. Otherwise you will not get precise code location but whole JITed code blocks.
  • »23.10.09 - 18:19
    BalrogSoft
    The problem is that even if trance is disabled, the only symptom is that appears black magic logo, then the gloom image, and nothing happens, the menu doesn't show. There aren't any alert, for this reason i was asking about log files.
    [ Edited by BalrogSoft on 2009/10/24 0:33 ]
  • »23.10.09 - 20:32
    zukow
    Posts: 657 from 2005/2/9
    http://dreamolers.binaryriot.org/logtool/
    or
    mossys:c/getramdebug
  • »24.10.09 - 05:52
    BalrogSoft
    This exactly that i was searching, now comes to interpret the log file to see what happens. Thanks you.
  • »24.10.09 - 09:21
    zukow
    http://www.biclodon.com/documentation/morphosdebug/chapter1.html
  • »24.10.09 - 09:23
