Posts: 2215 from 2003/2/24
You also need the MorphOS exe from http://www.pegasosforum.de/dload.php?action=file&file_id=663
Unpack the base archive .zip somewhere, open shell and cd into that game directory and write "protect #? rewd all", unpack MorphOS exe to same directory. Run the game.
BTW. I'd try first with only base archive and mos exe. If it works and if you want to try new gfx, then try those vgphd datas.
