uninstall Goa on MorphOS 2.0
    SoundSquare
    Posts: 1214 from 2004/12/1
    the thread's title says it all, how can i uninstall Goa from MorphOS 2.0 ?
  • »23.08.08 - 21:17
    Posts: 1076 from 2004/9/23
    Open a shell and type:
    delete SYS:Libs/Warp3D.library
    delete SYS:Libs/Warp3DPPC.library
    Thats all if you mean goa3d deinstallation.
    Geit
    [ Edited by geit on 2008/8/24 0:41 ]
  • »23.08.08 - 21:39
    SoundSquare
    got it ! thanks !
  • »23.08.08 - 21:53
    Crumb
    Posts: 736 from 2003/2/24
    Why you uninstalled it? Does it create any problem? Just curious...
  • »24.08.08 - 18:18
    SoundSquare
    As i installed it straight after MOS installation (too curious...) i wanted to uninstall it to see if i would have more chances running some mawi demos. But no (of course).
  • »24.08.08 - 18:55
    Crumb
    I have in my list of stupid things to do to test if switching MOS2 tinygl by MOS1.45 one would result in MAWI Demos working. Then I also would try to switch Rave3D drivers. I guess it won't work, but it may worth a try :-)
  • »24.08.08 - 20:08
    SoundSquare
    @crumb
    don't bother i tried that too and it doesn't work.
    Some users reported that the demos work on their peg, i don't knwo if that's because i have a peg1.
    Actually the demos start, but i only have the backgrounds and music, not the polygons...
  • »25.08.08 - 07:23
