Fix installer scripts...?
    td741
    Posts: 224 from 2003/4/2
    I've switched over my Efika to a MOS2.0 (registered). My old Peg system running 1.4 is currently in storage.
    I'm trying to set up my MOS2.0 system and installing some of the software I had find and running issues with faulty drive space checks in install scripts.
    I seem to remember a (Rexx? RxMUI?) script available (since MOS 1.3) that would fix installer scripts. I can't seem to remember the name of it? Help?
    Steph
  • »20.08.08 - 12:52
  • Targhan
    Posts: 2833 from 2003/2/8
    I believe you remember a script for actually installing MorphOS when the iso had the wrong MD5. HDInstallFix.
    It could be used as a template to work around your current problem, but don't run it.
    :idea:Targhan
  • »20.08.08 - 15:19
    td741
    Actually, I think it was ISPatcher?
    Steph
  • »21.08.08 - 12:53
  • Targhan
    Okay, the latest version of ISPatcher that I could dig up is 0.3. I've uploaded the file to the forums, since I don't see the download page anymore. I'll likely put it back in the download section before too long too.
    [edit] P.S.: Let me know if it still works!
    [ Edited by Targhan on 2008/8/21 9:07 ]
     Attached file(s)
    :idea:Targhan
  • »21.08.08 - 15:06
