Installing Wipeout2097 on Efika
    Zetec-s
    Posts: 198 from 2008/7/10
    Managed to get hold of a copy of Wipeout2097, but however hard I try I can't get it to install on my Efika.
    When I click on the install icon nothing happens. Any clues?
    Thanks in advance
  • »13.08.08 - 20:22
    Posts: 649 from 2004/4/15
    Just install the "installer" from Aminet to your "c" drawer.
    Installation went fine and Wipeout runs very fast on Efika.
  • »14.08.08 - 04:35
    Zetec-s
    Do you mean the Amiga installer from Amiga Technologies, or the one that is available for Morphos?
    Thanks
  • »14.08.08 - 06:04
    Oh, sorry,
    just checked which installer i copied to c.
    I used the one from amiga os 3.9
  • »14.08.08 - 15:20
    Zetec-s
    Dung out my old copy of OS3.9 and moved it across runs great. Although it did just freeze on me. Can't wait for the sound update for Morphos.
    You running your Efika with a usb CD-Drive? If so which one.
  • »14.08.08 - 16:25
    Posts: 3321 from 2003/3/5
    Check
    http://bigfoot.morphos-team.net/files/WipeoutLoader.lha
  • »15.08.08 - 12:43
    SoundSquare
    Posts: 1214 from 2004/12/1
    Once you installed the mentionned files above, just edit your user-startup file in Sys:S and add an assign :
    Assign WO2097: [the path to your install directory]
    eg : Assign WO2097: DH1:Games/WipeOut
    then reboot and launch the game.
  • »15.08.08 - 14:15
    Zetec-s
    Check
    That seems to have fixed it, thanks.
  • »15.08.08 - 16:21
    Zetec-s
    Looking playing this. Pity there is no sound on the Efika yet.
    Read somewhere that you can use a USB controller with this game, is that really possible? If so what sort of controller do I need?
  • »20.08.08 - 19:17
