Printing using MorphOS 2.0 on efika
    xyphoid
    Posts: 870 from 2008/7/11
    how do you print on efika using a usb printer?
  • »21.07.08 - 03:39
    tokai
    Posts: 1289 from 2003/2/25
    AFAIK you must select usbparallel.device as printer devince in printer configuration. Though.. I don't know more details, never tried myself, because I don't have an USB printer.
  • »21.07.08 - 06:54
    analogkid
    Posts: 722 from 2004/11/3
    And you must have luck to possess a supported printer. The included version of Turboprint is rather old.
  • »21.07.08 - 08:05
    zukow
    Posts: 662 from 2005/2/9
    maybe Mos Team could ask Isreesoft for SDK to make a new drivers
  • »21.07.08 - 08:49
    analogkid
    "ask" = pay, i would say...
  • »21.07.08 - 09:59
    Posts: 186 from 2003/10/23
    maybe we can setup a bounty?
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »21.07.08 - 10:25
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    @ xyphoid
    Yo already got a reply in the thread you opened previously...
    link
  • »21.07.08 - 11:22
    xyphoid
    @Doc
    thanks i did a not so thorough search!
    you will find useful information in the texts posted by Guido "geit" Mersmann on July 1 and 2 in the MorphOS Mailing List (thread: Printer support).
    Otherwise you need a USB printer. In such a case you can find instructions for printer configuration in the second part of this article (the first part of the article describes the installation of TurboPrint 7.60, but you do not need it if your USB printer is supported by the version of TurboPrint distributed in MorphOS 1.4.x and 2.0).
    how do i get to this info?
    i need to follow step by step to install a usb 2400series printer
  • »21.07.08 - 15:05
    cygnus
    Posts: 16 from 2008/7/1
    Here's what I do.. I have a NetGear print server with a HP LaserJet 1200 attached to it. And I'm using lpr-dev (aminet link below) which is a parallel port driver replacement. Then you basically configure the printing normally and just select the parallel port as the device.
    lpr-dev.lha
    This is working nicely on my Efika..
  • »21.07.08 - 15:44
    xyphoid
    any more suggestions? Not having much luck
  • »31.07.08 - 13:56
  • Bounty Manager
    insane
    Posts: 68 from 2003/5/20
    Hi raistlin77it !
    There ist allready such a bounty at pegasosforum bounty-bay:
    http://www.pegasosforum.de/viewtopic.php?t=3592
    The bounties just started 2 week's ago, so don't expect many donations at the moment...
    We founded the Pegasosforum-Bounties, because Morphzone-Bounties were "frozen" for a long time -
    Please Support Pegasosforum Bounties !
    [ Edited by insane on 2008/8/1 13:21 ]
  • »01.08.08 - 10:18
    thx for the info
  • »01.08.08 - 10:40
    xyphoid
    maybe I'm just not understanding. I'm assuming that morphos 2.0 on efika efika doesn't currently have a viable print option? for a simple HP2400 series usb printer!? :-x  :-x  :-x
  • »02.08.08 - 01:23
    Posts: 1087 from 2003/3/24
    @ xypoid: Maybe you should visit the Turboprint Homepage and look wich Printers are Supported or maybe you could check the supported Printers in the Printer Prefs.
    Then you would see that there is no driver for your Printer. That would help alot in that issue.
  • »02.08.08 - 06:58
    xyphoid
    No need to be a smart @ss! That was already established in the thread previously.. What I was looking for is a generic solution as in generic prefs as in os1.3-3.9! other options were mensioned, but i didn't get it! These are the type of responses which turn people off from amigas in general and further destroys the cause (As in if i may now not want to continue trial of this os, and opt for something MORE USER FRIENDLY!!) I have promoted amiga among all my friends, and morph to 4 so far. we need to work together to find solutions for each other.
    STOP BEING A SMART KNOW IT ALL, AND ASSIST PRODUCTIVELY......YEA I'M DONE!! :-x
  • »02.08.08 - 23:41
    I don't get it why the "Generic" solution in MOS-Prefs, is not generic enough.
    And i don't get it that you still assuming on the 2nd of august, after you have read the Arcticle of DoctorMorbius and should new wich printer is and is not supported by TP,
    that TP dosen't support your Printer directly. After reading the Article you should have know it for sure.
    And now here is a smart @ss advice for you, try all drivers from HP and maybe others that are in the TP-Prefs and maybe one of them works with your Printer.
    And if you like to support MOS and specially Printing then you could consider to donate to this Bounty
    Cos that is what move us all forward.
  • »03.08.08 - 05:20
