Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Legacy
monitor setting
xyphoid
# 1
Posts: 870 from 2008/7/11
I messed up and changed the screen size on the lcd tv, now the ambient screen is too large to select anything! any clues on how to set it back
17.07.08
01:23
xyphoid
# 2
Ok, i may not be doing his right. turn on my efika, let it load, interrupt the start with esc, then i typed
boot hd0: boot.img bootmenu
i didnt get it to go "error while trying to load or boot
What am i doing wrong?
18.07.08
03:46
Darth_X
# 3
News Moderator
Posts: 571 from 2003/2/10
boot from cd-rom
then whatever remains, however improbable,
must
be the truth!!! - Sherlock Holmes
18.07.08
06:31
Phantom
# 4
Posts: 381 from 2004/9/7
When you boot from cd, delete your screen prefs from the hard disk.
18.07.08
13:38
Henes
# 5
MorphOS Developer
Posts: 507 from 2003/6/14
Or boot as usual from your HD *BUT* press F1 to enter the boot menu, select a standard resolution (like 640x480x60) and change your prefs...
18.07.08
17:30
xyphoid
# 6
@Henes & Phantom
How do i change or delete the monitor prefs?
I want to keep the 1024x768 60Hz resolution but i was getting it in ambient settings.
19.07.08
02:10
