using Morph 2.0 with efika online
    xyphoid
    Posts: 870 from 2008/7/11
    how do I configure the tcp to go online (using serial port and dial up)
  • »12.07.08 - 02:13
    xyphoid
    where is the tcp stack? the serial port chips on and off during boot up and opening sputnik showing modem access
  • »12.07.08 - 11:49
    Krashan
    Posts: 1107 from 2003/6/11
    Built-in TCP/IP stack supports Ethernet connections only.
  • »12.07.08 - 14:39
    xyphoid
    see know...that's just whack!! NOT EVERYONE HAS HIGHSPEED!!! HOW IS ONE SUPPOSED TO USE THIS THEN OR REGISTER IF THEY DON'T HAVE INTERNET.
    NO SMART @SS ANSWER ABOUT JUST GET HIGH SPEED INTERNET THEN EITHER!! SOB!  :-x
    edit: On would think with a serial port this could be accomplished!! :-?
    [ Edited by xyphoid on 2008/7/12 12:41 ]
  • »12.07.08 - 15:30
    Piru
    Posts: 619 from 2003/2/24
    If nothing else works, you could set up a LAN between the EFIKA system and a PC or mac, and enable network sharing.
  • »12.07.08 - 15:55
    fryguy
    Posts: 16 from 2005/8/19
    Wouldn't it be possible to use Miami?
  • »12.07.08 - 18:17
    Posts: 37 from 2008/7/3
    @xyphoid
    Since MorphOS is AmigaOS Classic compatible, you could try some of the software for Classic AmigaOS. Another solution could be to use another computer to get online, and connect via LAN (as Piru suggested), or use a router (or network hub) that supports dial-up.
    If you have a spare PC that you don't need (could be the oldest box in town), you could install Linux or BSD on it, and configure it as a DHCP server. You could set up scripts to automatically dial your modem into the internet, and automatically terminate the connection (there are some tutorials for that AFAIK) when the connection is idle for a specified time. If that works, you'd simply buy a small network hub and connect all your boxes to it, including your "new" DHCP server. Then, you simply set up the remaining boxes as DHCP clients (i.e. in the TCP/IP configuration, specify "get TCP/IP address and DNS address from a DHCP server"). And you're all done, you'll never need to worry about it anymore. But it is a bit of work! ;-)
    [ Edited by voyager2007 on 2008/7/12 22:37 ]
  • »12.07.08 - 19:28
    Henes
    Posts: 507 from 2003/6/14
    Or try to use some ppp.device like f.e. this one and serial.device.
    And stop shouting.
  • »12.07.08 - 20:56
    xyphoid
    @Henes,Piru, Voyager2007
    Thanks, I'll give it a shot :-x
  • »13.07.08 - 00:47
    xyphoid
    no go...no serial.device in devs!
    edit ok found it, now if the windows would stop locking up
    [ Edited by xyphoid on 2008/7/13 0:24 ]
  • »13.07.08 - 03:18
    You can reduce the risk somewhat by setting the boot parameters to 2D layers (using "setenv boot-file boot.img rd rds 0" from OpenFirmware; this'll also free up the RS-232 by disabling the kernel debugger), and by unchecking the options "Drag/Resize windows with full contents" in IControl (accessible from the "Settings/System..." menu item) and enabling the option "Maximize windows on title bar double click" (avoids resizing). Use the "Screens" control panel to set a 24-bit color depth (simplifies color calculations), and the skin "Mahalaxmi" (simplifies window drawing).
    That's how it works for me. I used to get a lot of freezing, but it doesn't happen that often anymore. Hope that helps! :-)
    [ Edited by voyager2007 on 2008/7/13 10:26 ]
  • »13.07.08 - 07:21
    xyphoid
    couldn't get classic tcp to work
  • »14.07.08 - 03:53
