NIDE
    Posts: 16 from 2003/10/22
    Hello !
    Please, I need help :
    ImageFX4.5 crashes after open...
    Log attached
    Thanks a lot.
  • »10.07.08 - 15:40
    Thanks a lot !
    ImageFX4.5 works fine now.
  • »11.07.08 - 07:00
    Piru
    Posts: 624 from 2003/2/24
    Just dropping in to mention that the IFX "thumbnail" stuff will work again with the upcoming MOS 2.x update. Meanwhile it's indeed necessary to use ASL requesters and disable the thumbnail generation.
  • »11.07.08 - 07:50
    jcmarcos
    Posts: 1178 from 2003/3/13
    So, another thing fixed! Is there any estimated date for this update? Will you wait more time, in order to catch more bugs?
  • »11.07.08 - 10:22
    Posts: 1087 from 2003/3/24
    @ Piru: Men thats unbeliveable to get a MOS update or bugfix in such a short time. Great!!! :)
  • »11.07.08 - 13:32
    Kamul
    Posts: 121 from 2004/6/9
    I think you should wait with your enthusiastic comments till this update will be available. :)
  • »11.07.08 - 13:48
