How to Transfer Classic Amiga Software?
    Posts: 37 from 2008/7/3
    I have an A-1200 with OS 3.0, an Efika with MOS 2.0, a PC with Unix, a null modem cable, and I would like to know if there's some software I can use to transmit files.
    Like, I could transfer files from Amiga to Unix and from there to MOS, or directly from OS 3.0 to MOS 2.0. Which software can I use to accomplish that?
    Also, is there a way to connect an Amiga floppy drive to a USB port, or if there's a way to connect any floppy drive (that can read Amiga disks) to MOS 2.0 on Efika.
    Any help would be appreciated! :-)
  • »06.07.08 - 12:48
    Phantom
    Posts: 381 from 2004/9/7
    The best and the easiest way to transfer files from the Amiga is to buy this from AmigaKit:
    http://amigakit.leamancomputing.com/catalog/product_info.php?cPath=42&products_id=440&osCsid=5f0dca8c379cb0bfbb2c6b72709bef2a
    It's a CF adapter. Of course you will need a CF card reader to the peecee.
    With null modem cable, is another way to transfer files, but I really never tried that.
    When I want to transfer files to MorphOS I always used a USB stick.
  • »06.07.08 - 13:10
    Henes
    Posts: 507 from 2003/6/14
    I would say you can make a LAN between the Efika and the Amiga using the null modem cable and some device I do not remember the name of (must be on Aminet or part of some TCP/IP stack).
    I used to put an A600 online this way, using another machine as the gateway.
    And use the PC + the Amiga's crossdos filesystem to copy the required binaries to the Amiga.
    This solution requires you to buy...nothing :-)
    [ Edited by Henes on 2008/7/6 15:17 ]
  • »06.07.08 - 14:17
    @Henes
    What's its name? I remember using ParNet once, but that works only between Amigas. There must be something using the serial interface. There is some software included in AmigaForever (AmigaExplorer), but I don't have a Windows box up and running right now.
    My current PC has no floppy controller; hence, it's impossible to connect a floppy drive to it. Things would get complicated if I would use one of my old Windows boxes (broken CD burner, Samba setup hassles on Unix; I could use an FTP server though).
    But thanks for reminding me! I haven't even thought of that! Perhaps I can use it as an intermediate solution. :-)
  • »06.07.08 - 14:30
    @Phantom
    Thank you!! :-)
    I've ordered myself one, and a USB CF reader for my PC. (the latter one was long overdue anyway, since I have a camera using CF but no card reader, only USB, which nowadays can incur problems on Unixes, because they try to mount the camera as a camera, not as a USB drive! ;-) ).
    Yeah, I would like to know which software to use for that.
    Yup, that's good for between MOS and Unix. Are there any USB kits for Amigas?
  • »06.07.08 - 14:36
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    @ voyager2007
    This suggestion is useful only if all your computers are connected to the same modem/router for common access to the web.
    In such a case, the simplest way to exchange data between your computers is to download rc-ftpd from Aminet and use it to set your Amiga or Efika or Pegasos as a FTP server to which you connect the other computers (in the LAN created by the router) by means of an FTP client like AmiTradeCenter.
  • »06.07.08 - 14:46
    Henes
    @v2097
    I guess it was some SLIP device.... so slip.device maybe? :)
  • »06.07.08 - 14:58
    Thank you, guys!! :-)
  • »07.07.08 - 02:24
