MorphOS wont boot
    Charvel
    Posts: 97 from 2007/2/15
    Hi!
    And thanks again for the release. I have booted from the cd and so far it looks VERY good :) .
    Now, here comes my problem. I have a new harddrive.
    How do I set up my partitions? I have a peg 1.
    In the installationprogram I choose the bootable partition and installs everything but when I reboot. it just says "quark" and nothing more happens.
    I bought this peg with 1.4.5 for a half year ago and I never reinstalled so I dont know how to do really.
    1.4.5 was very stable and worked flawless on my peg.
    I have
    DH1 capacity 705 free 586
    DH2 capacity 6GB free 4GB
    DHX capacity 78mb free 72 mb.
    All of them ffs.
    //Peter
    [ Edited by Charvel on 2008/7/2 18:20 ]
  • »02.07.08 - 17:12
    Cego
    Posts: 734 from 2006/5/28
    copy the bootpeg1.img from the cd to your boot partition, just replace the existing one.
    your boot partition is probably DHX.
    best regards cego
    [ Edited by Cego on 2008/7/2 17:51 ]
  • »02.07.08 - 17:50
    Charvel
    Thanks! :)
    I did copy the boot.img but that one is only for peg 2 I asume........
    Now I will try to reboot.
  • »02.07.08 - 17:54
    Charvel
    YES!!!!!!!
    IT WORKS!
    I now have MorphOS 2.0 working =) =) =)
  • »02.07.08 - 17:56
    Cego
    you should use the bootpeg1.img for the peg1. you can rename it to boot.img and replace the other one. just be to sure, that there wont be any wierd behaviour of the system.
  • »02.07.08 - 17:59
    bennymee
    Posts: 133 from 2004/4/14
    Do you really have to do the manual copy ?
    I reformatted my harddrive, made 2 partitions: bio (automount), dh0: (autoboot).
    I then installed to dh0:
    And reboot, but system does not boot and halts by the firmware prompt.
    [ Edited by bennymee on 2008/7/3 18:02 ]
  • »03.07.08 - 17:01
    hooligan
    Posts: 1948 from 2003/2/23
    There is now a FAQ
    Jobbo made a news about it 15 seconds ago.
  • »03.07.08 - 17:17
    bennymee
    Thank you Jobbo !
  • »03.07.08 - 17:23
