Problem getting MOS to work on 1200/PPC/BVision
    astral
    Posts: 1 from 2008/5/27
    I have a 1200/PPC/160Mb which works with OS3.9 and OS4 fine. I thought I'd try MOS. I copied MOS to a FFS formatted highest priorirty bootable partition. All I get when MOS tries to load is a black screen and the monitor does not switch on. What settings should I be playing with to get this thing working?
  • »27.05.08 - 06:51
    Crumb
    Posts: 737 from 2003/2/24
    -do not use ROM3.1 and use fakerom.elf.
    -use module1.rom.idefix instead of module1.rom
    -change startup-sequence using CED or GoldED. Do not use ED/MEmacs/Notepad.
  • »27.05.08 - 07:05
    CLS2086
    Posts: 168 from 2005/8/25
    have you well tried the Readme on the disk ???
    I'm not sure, if you did you might have found a file to replace about IDE driver file...
    Replace/rename it...
    Use EditPad of OS3.9.
    I use a patched 3.1 ROM !
    [ Edited by CLS2086 on 2008/6/22 11:51 ]
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »22.06.08 - 08:50
