Can MorphOS run without a gfx-card ?
    Develin
    Posts: 100 from 2003/4/19
    Might sound like a silly question, but can I start my Peg2 running MorphOS without my Radeon 9200 attached in the AGP-socket ?
    Due temporary limitation I need to use my machine through VNC and just wonder incase it's possible to skip the gfx-card and still have MOS up and running on the machine ?
  • »28.05.08 - 08:27
    Posts: 3264 from 2003/3/5
    Nope, it cannot run w/o a gfx card.
    I once thought about creating a virtual CGX driver which would work in memory to allow using VNC w/o a real graphics card, so I might be willing to accept a bounty after MorphOS 2.0 is out.
  • »28.05.08 - 09:53
    Develin
    @jacadcaps
    Ok, thanks for the info.
    I'll support you in such bounty for sure =)
  • »28.05.08 - 10:19
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    First we should hope that MorphZone bounties return to life...  :-x
    This is an old story.  :-(
  • »28.05.08 - 10:39
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    It precludes it from being used in an embedded device/system.. ?
  • »28.05.08 - 20:15
    Does MorphOS support one?
  • »29.05.08 - 04:16
    jcmarcos
    Posts: 1178 from 2003/3/13
    I once thought about creating a virtual CGX driver which would work in memory to allow using VNC.
    That's a good idea, and exactly what I once had in mind as a proposal.
    I think that MorphOS can be put to good user in the server space. One immediate asset that it would have is that, being such a strange operating system, is much less prone to attacks...
    Jokes aside, perhaps MorphOS can't be better than any regular Linux, because the services it might run (Apache, MySQL, for example) are programs for Linux, and a "simple" (ahem) MorphOS port can't make them any better.
    Would it have any advantage running them in MorphOS? Only an hypothesis, of course.
  • »29.05.08 - 04:45
  • Bounty Manager
    insane
    Posts: 68 from 2003/5/20
    We are building a new bounty-system on the german pegasosforum.
    (www.pegasosforum.de --> FORUM --> Bounty Bay)
    Until now it's under constrcution, but we look forward to launch
    it in the next 2-3 weeks.
    Then, the important "threads" will be available in english too!
    The listed bounties are suggestions for now, there will be a procedure (?) -
    because for the beginning we start only with about 5 of them.
    Off course self-bounties will be possible...
    Insane
    [ Edited by insane on 2008/5/29 14:18 ]
  • »29.05.08 - 11:12
    CountRaven
    Posts: 566 from 2007/12/10
    good news about this bounty-system :)
  • »06.06.08 - 15:27
