hmmm, Snatchdiz?
    XzIt
    Posts: 250 from 2005/1/19
    Anyone use snatchdiz?
    having some problems here with it, it won't find file_id.diz files in my archives...
    Soo, i started snoopdos and retried, suddenly it found the file_id.diz and outputted. but when i stopped or quiet snoopdos it stops working...
    Any ideas??
    X
  • »18.05.08 - 16:00
    Posts: 2215 from 2003/2/24
    Hmh.. doesn't work here either. Snoopium reports it extracts file_id.diz to t: correctly and snatchdiz reads it, but then nothing is outputted. With listfile it outputs filename and size, but no file_id.diz... weird.
    I've been using FileDiz for years and it works fine on MorphOS too.
  • »19.05.08 - 11:53
    XzIt
    thanks, i'll try that one then :D
    X
  • »20.05.08 - 09:31
