Kompaktor will come soon.
    serge
    Posts: 725 from 2003/2/20
    Hi guys,
    Rusback, the bourriquet dev is finishing a nice packer/unpacker with winrar GUY style for morphos.
    LHA only is supported on the first release, but on next releases, more formats will be added like ZIP.
    It's always dificult to make or edit archives, but with Kompaktor it's fingers in the noise ;-)
    Here are some screen shots.
    Kompaktor creating an archive
    http://serge.free.free.fr/Pegasos/kompaktor/new.png
    Kompaktor adding files to an archive
    http://serge.free.free.fr/Pegasos/kompaktor/mov.png
    Kompaktor extracting an archive
    http://serge.free.free.fr/Pegasos/kompaktor/Kompaktor%20fenetre%20extract.jpg
    Kompaktor listing an archive content
    http://serge.free.free.fr/Pegasos/kompaktor/liste%20of%20infos.png
    [ Edited by serge on 2006/4/19 22:22 ]
    [ Edited by serge on 2006/4/19 22:23 ]
  • »19.04.06 - 18:58
    Posts: 1087 from 2003/3/24
    WOW i like that screenshots and that hot chick :-)
    Hope we see a new version of bourriquet soon.
  • »19.04.06 - 20:06
    Crumb
    Posts: 737 from 2003/2/24
    Looks great :-)
    It would be nice if it was possible in Ambient to create context menus for each icons, so you could select one or more icons, press the right mouse button, a context menu would pop-up and you could choose the option of compressing an entire directory using Kompaktor...
  • »20.04.06 - 06:04
    Jupp3
    Posts: 1193 from 2003/2/24
    How about being able to mount an existing / new archive as a read/write drive? Now THAT would be cool... Well, maybe some day... :-)
  • »20.04.06 - 06:24
    jcmarcos
    Posts: 1178 from 2003/3/13
    I've searched in Aminet, and was only able to find Tar_handler, which is a very old tool to mount TAR files. Sure no LHA-mount exists?
  • »20.04.06 - 06:57
    beanbandit
    Posts: 50 from 2006/4/19
    why does he not utilise (port) the opensource xadlib?
    it's got unarchivers comning out of it's ears (but some would need some work -RAR-) unfortunately it's only for unarcing, so perhaps it falls on that... has anyone ported xadlib to mos?.
  • »20.04.06 - 08:02
    Wishmaster
    Posts: 342 from 2003/6/29
    Why port, you can use the 68k version.
    I am using Filer for Archivehandling.
    Pegasos PPC
  • »20.04.06 - 09:46
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Jupp3,
    it's already possible to add such global actions to files/dirs. The limitation ATM is that it only applies to individual menu and not group menu.
  • »20.04.06 - 09:49
    Bladerunner
    Posts: 418 from 2004/2/19
    Nice one :) So I am finally able to replace my good old MiraWizArc which is, surprise surprise no longer working with Mui 4.0 (really hope all that incompatibilities get sorted before the final release...)
  • »20.04.06 - 09:55
    GK_LKA
    Posts: 481 from 2004/3/28
    Very nice :)
    But until it supports only lha I'd stay at Voodoo-X. :)
    [ GK / LKA Team ]
  • »20.04.06 - 10:24
    Bladerunner
    GK_LKA:
    Well, Voodoo X doesn`t support packing, so it isn`t a real alternative here ;) However I agree that it would be nice if Kompaktor will support XAD for unpacking tasks.
  • »20.04.06 - 10:37
  • Fab
    Fab
    bladerunner,
    what doesn't work in mirawizarc with mui4 btw ?
  • »20.04.06 - 10:39
    Fransexy
    Posts: 25 from 2005/9/14
    bigdan wrote:
    For Kompactor screenshots, look :
    or
    Edited by bigdan on 2006/4/19 22:22 : sorry Serge edit his post while i reply !
    I love it (and also the girl of the backdrops  :-D )
    It will be open source(the app, not the girl ;-) )
    Any hope for a OS4, OS3.x and/or AROS version?
  • »20.04.06 - 10:47
    Bladerunner
    Fab:
    It has the same Problem as Wildfire has, it is impossible to select a path. Mirawizarc allways jumps to t: if i try to add a subdir for packing on any device other then ram: , Wildfire has a similar problem where I can`t pass a path when I change a project or start a new project. My Workaround for wildfire is to manipulate the project files which are just plain textfiles. The MUI 4 beta which was "leaked" here previously showed the same behaviour, so I guess it is either unnoticed or considered not worth to be fixed. (Well I can`t even say if this is a "bug" or belongs to the part in the readme where it was said that some MUI apps will possibly brake. I simply don`t have the knowledge about that issue. However it is actually a real Problem for me.)
  • »20.04.06 - 10:57
    serge
    @ Fransexy
    Kompaktor will be freeware.
    At this time, it's plained a MUI / MOS version, then Feelin / MOS and then, why not a feelin / OS4 or Felling /OS3. Just have to ask rusback for it ;-)
    [ Edited by serge on 2006/4/20 14:41 ]
  • »20.04.06 - 11:41
    samo79
    Posts: 87 from 2003/7/26
    Cool !!
    Thanks Rusbeck :-)
    BACK FOR THE FUTURE
    http://www.betatesting.it/backforthefuture
  • »20.04.06 - 14:55
    mobydick
    Posts: 179 from 2004/2/26
    serge wrote:
    Hi guys,
    Ooo... Thats coooolll!!!
    How about 7zip?
    peguser.narod.ru
  • »20.04.06 - 16:35
    analogkid
    Posts: 720 from 2004/11/3
    looks good! especially the possibiliy to edit archives is very pleasant to me :)
  • »21.04.06 - 07:26
    beanbandit
    7zip already exists for morphos see at morphos-news
  • »21.04.06 - 14:15
    mobydick
    I mean, is it possible to support 7zip in Kompaktor?
    peguser.narod.ru
  • »22.04.06 - 01:35
    Fransexy
    What happened to kompaktor?  :-?
  • »28.02.08 - 14:58
