SMBFS - Windows Vista
    Posts: 236 from 2003/7/28
    Does anyone know if there is a working SMBFS for MorphOS that will work with Windows Vista shares?
    I can mount the share, browse the directory, but as soon as I try to access or copy a file from the share, SMBFS hangs.
    I have adjusted the share authentication to try and make it compatible (tried all settings) to no avail.
    Anyone have any ideas?
  • »30.12.07 - 21:27
    matt3
    Posts: 780 from 2004/2/10
    Hi HammerD:
    Make sure your using Miami and not MOSNET. MOSNET does not work with SMBFS.
    As far as Vista I haven't tried it...
    Take care,
    Matt
  • »30.12.07 - 21:48
    Toto
    Posts: 268 from 2003/4/20
    SMBFS does work with MosNet, I'm using it succesfully to acces my Linux shares. As for Windows Vista; I don't know, I don't use Windows.
    Cheers,
    Salvatore
  • »30.12.07 - 22:04
    Framiga
    Posts: 363 from 2003/7/11
    have you already set this security win crap?
    Vista security
  • »31.12.07 - 08:22
    Yep, tried that, no luck.
  • »31.12.07 - 14:48
