Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Legacy
MOSnet and Wifi
SoundSquare
# 1
Posts: 1214 from 2004/12/1
I just plugged a prism2 wifi card in my Pegaos and i was wondering if MOSnet can handle it ?
How can i set the SSID and WEP settings with MOSnet ?
thanks for your help
05.04.07
18:22
Toto
# 2
Posts: 268 from 2003/4/20
I've got a wifi card in my Pegasos and it works fine with MOSnet. You have to put the SSID and WEP settings in your user-startup, like this:
SetPrism2Defaults SSID wlan1 KEY 1234-abcd-89
SetPrism2Defaults SSID wlan2 TEXTKEY asecreTwePkeY
SetPrism2Defaults SSID mynet ADHOC CHANNEL 11
These are examples from the Prism2 manual.
~toto
05.04.07
18:39
SoundSquare
# 3
thanks a lot Toto, i'll try that tonight !
05.04.07
19:03
wali7
# 4
Posts: 24 from 2007/3/10
I have some old Prism2.5 card taken from may laptop (it is in miniPCI format), so could anyone tell me if it is possible to use it with my PegasosII under Morphos? Of course I know about the necessity of using miniPCI<>PCI interface card.
17.10.07
21:35
