File Requestor Window problem
    Posts: 8 from 2006/4/1
    Arghhhhh! Someone please help before my head explodes.
    About 3 months ago I installed the latest nightly build of Ambient Desktop, and I also installed MUI Alpha 4. Since then whenever I run a program which opens a file requestor everything is fine, unless I wish to choose a file residing on another device. When I do this it says "Application Meditating" etc etc and I have to reboot. For instance. I might run MPlayer, it will pop up a file requestor window. Then I click on the root button, or parent back to see a list of my available devices, choose "Video Applications:" (which is a HD with all of my video files on it. The window crashes - Application is Meditating etc.... I am going insane!!!
    I have tried fiddling with the MUI and Ambient settings but nothing seems to help.
    Please please please help.... :(
  • »08.04.07 - 00:04
    analogkid
    Posts: 716 from 2004/11/3
    Have you installed a z.library? if yes, delete it. It isn't compatible with the MUI-ASL Requester.
  • »08.04.07 - 02:27
    THanks for the reply. Erm, I cannot remember installing a z.library... actually, to be honest I have no idea what that is, where it is and how to check for it.... is it in sys:libs?
  • »08.04.07 - 06:46
    Hey there. I found it in sys:libs/ deleted, rebooted and... problem is gone!!!
    Thanks Analogkid!!! But, how did you know? Was this a common problem when MUI 4 Alpha first came out?
  • »08.04.07 - 07:04
    analogkid
    Yes, it was a common problem when the first MUI4 versions appeared.
  • »08.04.07 - 07:16
