Any Tracker runs fine on mos1.4??
    Doraemon
    Posts: 137 from 2003/7/1
    Anyone have a tracker running in mos???
    Please help!
  • »18.08.03 - 09:29
    Posts: 261 from 2003/3/13
    DOn't think there's any tracker that will work on mos, i tried them all, even AHI based ones.
    But then again, PSA wich comes with the superbundle works great! And is far more interesting then any tracker :)
    BTW: Anyone tried DSPSpeed ?:)
    Felix.
  • »18.08.03 - 10:17
    Posts: 26 from 2003/4/21
    Has anyone found a way for exact positioning of e.g. drum samples?
    I mean, creating drum loops with different samples on different tracks
    on a grid or something similar and copy and paste it a number of
    times?
  • »18.08.03 - 20:07
    Quiet here...
    but I'll try it again ;)
    has anybody out there managed to get SoundFX working?
  • »21.08.03 - 23:12
  • HAK
    Posts: 225 from 2003/2/24
    @ beasty,
    Well, I tried the SFX 4.1 Demo version.
    It works - at least the few functions I tried.
    Bye HAK
  • »22.08.03 - 00:09
    realstar
    Posts: 298 from 2003/2/24
    Do you mean in ProStationAudio? You can loop/repeat and
    position samples in up to 16 tracks at once with precise
    timing. :)
  • »22.08.03 - 01:20
    How do I do so?
    Can I place the cursor to a position and move it forward with a
    distance set before?
    How?
    SoundFX: It seems to work here, too, but I cannot change the prefs
    without crash afterwards. Also the SFX hangs when trying some sound
    edit functions.
  • »22.08.03 - 12:04
  • HAK
    @ beasty,
    SoundFX: I can change/save the prefs and the program still works.
    Also the few functions I tried seem to work - except that I get a "Not
    enough memory" sometimes (having 256 MByte).
    BTW: I'm using MOS 1.4 (I had no luck with MOS 1.3 and SFX) and the
    68000 Demo version 4.1.81 from SFX.
    Bye HAK
  • »22.08.03 - 13:35
