IBrowse Toolbar problems
    Posts: 47 from 2004/4/11
    Hi there,
    when i put my fastlinks/transferanim into the IBrowse toolbar then i only see the navigation buttons. The fastlinks/transferanim is there but i cant see them. Only when i click on the place where the fastlinks/transferanim are then they will appear but when i refresh or resize the IBrowse window they disappear again.
    Does anyone know how to fix this problem?
    Bye
    TriMa
  • »17.06.04 - 11:48
    Mitya
    Posts: 33 from 2004/5/13
    works fine by me
    no problems with Ibrowse here
  • »17.06.04 - 12:26
    And ur fastlinks or transferanim is really in the toolbar too?
    Maybe its a configuration problem but i didnt found it.
    Does no one had a clue what the problem is?
    Bye
    TriMa
  • »18.06.04 - 10:42
    BatteMan
    Posts: 294 from 2003/2/24
    No solution if you want to put the fastlink in the toolbar... sorry
    But, all is good if you put fastlink under toolbar or anywhere, but not IN the toolbar.
  • »18.06.04 - 12:40
    mikeri
    Posts: 13 from 2006/7/27
    Yes, I know this is an old thread.
    I have the same problem, even after upgrading to MUI4 and IBrowse 2.4. It works fine on AmigaOS, however.
    Has *anyone* got this to work yet? No, I don't want the fastlinks under or above the toolbar.
  • »23.12.06 - 23:13
    tokai
    Posts: 1289 from 2003/2/25
    This is a stoneold problem. Simple solution: don't put the fastlinks into the toolbar; keep them extra.
    GUI -> Show fastlinks buttons <-- activate this
    GUI -> Navigation Toolbar <-- remove fastlinks here
    If you need Fastlink buttons in the toolbar you easily can do this additionally to the normal fastlink buttons:
    Just drop a custom button to the toolbar:
    Label: MyFastlink
    Action: URL http://myfunkylink.com/
    Done. You even can add some image for it if you want. Well.. I don't like images here, but well.
    here u see how well this works (even with MUI4 ;) :
    http://tokai.binaryriot.org/ibrowse24.png
    regards,
    tokai
  • »24.12.06 - 07:03
