MovieShop?
    jaesonk
    Posts: 12 from 2005/12/2
    Hello,
    Has anyone tested MacroSystems MovieShop & VLM/Toccata running under MorphOS on a classic Amiga? If it works, are there any speed comparisons to share?
    I'm going to create a MOS setup on my A3KT/CSPPC when I get another drive installed.
    Thanks,
    Jaeson K.
  • »02.12.05 - 15:49
    Tcheko
    Posts: 544 from 2003/2/25
    Any result?
    Same setup. Never tried MOs with my vlab motion.
  • »08.10.06 - 16:24
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    In the MorphOS 0.x times, i could try such a setup and it worked very fine, better than with amigaos and a 68060 (performance-wise). Now i can't tell if it still works with MorphOS 1.x, but chances are it still does.
  • »08.10.06 - 17:26
    magnetic
    Posts: 2129 from 2003/3/1
    Fab,
    If this is the case a 4000/ppc running Movieshop would be awesome. It would be great if we could get a working report with 1.4.x
    magnetic
  • »08.10.06 - 19:57
    Doraemon
    Posts: 137 from 2003/7/1
    Since my peg2 its dead, I will test mos in my 1200ppc.
    I have z4 board with tocatta and motion, and of course I will test movieshop ASAP.
    Now im not at my home, but in 3 days I will do it, sure!
    Wishme good luck :)
  • »09.10.06 - 08:36
    magnetic
    Doraemon
    Sounds great. Cant wait to hear the report.
    magnetic
  • »10.10.06 - 15:26
